Honda S2000 Honda S2000
problems after headgasket change
Old Jan 22, 2015 | 06:32 PM
raverx3m's Avatar
Default problems after headgasket change
changed headgasket put it all together according to service manual best I could I triple checked the timing chain marks and the black links and all that sht.
at first it wouldn't start then it started and ran for 2 days I did valve adjustment then took it for a test drive and it was studdering on acceleration very bad almost dying during throttle tip in
idles rough.
didn't find any vacuum leaks either
after the test drive I let it idle and after about 10 minutes idling it just shut off like it lost ignition. didn't stumble just stopped running like when you turn the key off and didn't start back up
I plugged in the scan gauge and theres no codes and everything looked good.
it had a cooland blowout on the headgasket but otherwise had no problems before that
I never worked on s2000 so don't know any specific tricks or other crap that these cars are sensitive about.
I did get the service manual and everything is torqued to spec and aligned to spec as far as I can tell
mtdineen
Oct 27, 2014 09:16 AM
Hugo Rego
Honda Civic (2001 - 2005)
Aug 16, 2014 04:02 PM
jon9116
Nov 9, 2013 11:58 PM
mattL
Dec 11, 2002 10:08 AM
jdm_ef9
Jul 23, 2002 06:17 AM
