Honda S2000 Honda S2000
Oil Pump Rotor Problem?
Old Jan 5, 2014 | 02:47 PM
phantom90333's Avatar
Default Oil Pump Rotor Problem?
When my car finally gets warm my oil pressure drops to around 6 psi at idle (850 rpm). I made sure there were no leaks and that everything is installed properly to no avail.
I ended up pulling my oil pump and saw that the rotors look strange. I have attached pictures of the rotors. I was curious if this is what a new pump should look like or if some damage may have occurred(looks pitted but might just me machining). The motor and pump only have about 5 miles of light driving and 30 minutes of idle on jack stand.
Old Jan 25, 2014 | 09:07 AM
Runnerdown's Avatar
Default Re: Oil Pump Rotor Problem?
There does not appear to be any significant damage to the rotors, however it's clear that the pump has ingested debris of some sort. When it comes to rebuilding engines, cleanliness is godliness. Good luck.
Mr. Future
Nov 22, 2015 07:46 PM
njmoro2
Honda Civic (2006 - 2015)
Nov 6, 2010 09:10 AM
Griffin@Camtech
Apr 14, 2004 04:41 PM
