green key flash
picked up a "project car" anyhow, when tested with starter fluid. it started up find then dies. before that he did mention theres no gas left. theres no cat so it was loud couldnt tell if the engine was smooth. i end up buying it still. today i added gas and battery. cranks up and you can hear the exhaust but dies right away. from what i've googled. it could be the main relax (couldn't find it) anyone got the location? it also could be the immobilizer since the green key does flashes after i removed it but doesn't show when key is in..is that normal?
I would hope you have already changed the oil before trying to start it if it has sat for a long time?
It's just like strong carb cleaner, just think of it as spray gas.
started the car at the old owners place. we only tried it once and it was loud cause there was no cat. stayed on about 2 sec. he also said theres no gas. well, today i removed the main relay and just ordered one on ebay. hopefully this is the fix.
can't doesn't stay up long enough for it to warm up but might have to check still. don't even have the tools...yet
smash fascism
21
Nov 6, 2005 03:52 PM
