Honda S2000 Honda S2000
Is this good for a s2k???
Old Dec 19, 2008 | 11:07 AM
ep3freak07's Avatar
Default Is this good for a s2k???
Wheel Diameter - 17"
Wheel Width - 7.5"
PCD Bolt Pattern - 5x114.3
Offset - 45mm
Hub Bore - 73mm
Color - White
Old Dec 19, 2008 | 11:18 AM
White Smoke's Avatar
i my honda
Global Mod
No, not really. Factory wheels are staggered and wider then those in the rear. You will be downgrading.
Old Dec 19, 2008 | 11:35 AM
ep3freak07's Avatar
so what will i have to look for then.
Old Dec 19, 2008 | 11:51 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The wheels you listed would be good for a civic or something.
Your question is very vague. Look at the "clean S2000" picture thread. See what "look" you like and ask the owner what size/offset they are and what they had to do to make it work.
Old Dec 19, 2008 | 11:56 AM
B serious's Avatar
I should add that the front wheels in a 17X7.5 +45 will work great. I have that right now. It will look stupid as hell on the back, though. IIRC, the stock AP2 wheels are wider than 7.5''.
You don't nessecarily have to go staggered...but if you get an agressive enough rear size, you will have to mod the front fenders for the fronts to work.
Old Dec 19, 2008 | 01:48 PM
iHEARTmyFERIO's Avatar
stock AP2 wheel sizes are 17x7 and 17x8.5, on 215/45 and 245/40 tires.
if you're getting a set of 17x7.5 tires, might be a good thing to stagger the tires. 215 in the front, 235 in the back. a spacer might also be needed.
most ideal for you is to scrap the idea of 17x7.5 on all fours and consider running staggered to keep your stock handling characteristics.
Old Dec 19, 2008 | 06:31 PM
B serious's Avatar
^ You can't run a 235 size to correspond with the stock sizing. The diameters of available 235 sizes are not right.
The stock rear size on an AP2 is a 245. The stock AP1 tires are the size of normal 245s even though they are technically 225s.
Why 235s?
Old Dec 20, 2008 | 07:07 PM
b17rider's Avatar
Why 235s?
have you been driven your S in this snow just curious?
Old Dec 22, 2008 | 08:37 AM
B serious's Avatar
Default Re: Is this good for a s2k???
Hell no. I have an EM1. My S2000 gets stored.
What does snow have to do with anything?
Old Dec 22, 2008 | 08:59 AM
Why 235s?
it's just the widest possible tire for a 7.5" width wheel. and yes, i'm aware that s2k rear tires are 245, if you carefully read my post.
i was just suggesting 235s in the back because if he's going with a 7.5" wheel all around, might as well try to keep the stagger even though it's not the same as stock sizing.
Old Dec 22, 2008 | 02:11 PM
B serious's Avatar
Allright, but again, there is no 17'' 235 width tire that has the same diameter overall as the stock AP1 or AP2 tires.
It's either 215/45/17, 225/45/17, 245/40/17, or 255/40/17. Those are all very close to stock diameters.
Old Dec 22, 2008 | 02:32 PM
Originally Posted by ep3freak07
i am going get the Work Emotion XD9 Wheels what offset should i get.
17x7.0 5x100 is that good.
thanks
you're a troll.
Old Dec 22, 2008 | 06:44 PM
B serious's Avatar
Have we been had?
eg9
Wheels
10
Aug 27, 2012 02:54 PM
primaryOBSESSION
Honda S2000
12
Mar 11, 2009 09:30 AM
Sean @ ESG
Nov 26, 2008 07:32 PM
MJ0LNIR
Jan 15, 2007 08:53 PM
budget
Jun 25, 2006 08:29 AM
