Honda S2000 Honda S2000
Door panel removal
Old Aug 7, 2008 | 05:40 PM
Nuts's Avatar
Default Door panel removal
Hi all, I did my search and only come up with the following broken link
http://lucidauto.com/Merchant2...aks2k
Can anyone point me to the guide in removing the door panel/cards? Also does AP1 & AP2 door panel interchangable?
Thanks
Old Aug 7, 2008 | 06:32 PM
dartonh22's Avatar
Default Re: Door panel removal (Nuts)
its really easy to remove the door panels there are two screws in the door panel grip handle
and i belive one more on the actual door handle opener
and maybe one more towards the dashboard.
once all the visible screws are out just pull out on the bottom of the door panel and it will pop out then pull up to remove it from the door.
its really not hard at all just look for screws and remove them, some are under little tabs that need to be pryed out.
i removed my panels a while back to adjust my window so i dont remember it step by step
i didint remove the inserts but they have tabs behind them that once pryed should remove them from the panel, thats how my prelude was.
todd.ludwig
May 1, 2006 02:27 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
[HrZn]4life
Feb 11, 2003 01:21 PM
teg95
May 22, 2002 01:16 PM
onyx00
Sep 5, 2001 12:44 PM
