ABS light
Sorry did a search but nothing came up..
This happened a few days ago, i been working 12 hours shifts so i havent had time to look into it yet, but maybe someone can help me out. Every now and then my ABS lights comes on right when u start up the car.. some times it comes on during a drive and stay on until the next start up... but here's the strange part.. when ever my ABS light comes on, my heater/ac turns off, and the side mirrors wont adjust.. have anyone experience this problem before?
When my trunk light when out the other day I threw the R/C Mirror fuse into it's place for the day. Low and behold the ABS light came on. So they're on the same circuit. New fuse and the light is gone now. However, I'm certain the AC still worked. Sounds like a short, which I'd much rather have than ABS failure.
my abs light comes on about 1/2 the time i'm driving. sometimes it goes off but it usually stays on once it comes on. usually it's triggered by a bump going onto or off of a bridge. abs still seems to work but the light is getting annoying.
edit: but my a/c and heat remain working regardless
process of elimination? i suggest, check fuses, get it diagnosed as stated before, and check and make sure all your abs sensors wires arent cut, and check the abs sensors one by one. hope this helps.
My 05 Mugen S2000 does exactly the same thing (why i found this Forum/link-I am not alone!). Usually from first switch on, not every time. Pulled fuses but who knows will have to get the dealer to check. If it dosn't reset I usually pull over and switch off/restart and it works.
Abs light comes on goes off (but actuallt ABS still working) occasionally the AC and all heater switch actions don't work then reboot.
Hell i brought it for the 278BHP its kicking so will live with it for a while.
