12V Sounce When Engine Is Running???
OK...I am installing Day Time Running lights using the Hamsar Visi-Light Module # 45040. I have everything connected but for the last wire it says to either wrap it around a spark plug wire a few times, or find a 12V source when the ignition is in the run position. Now it suggests the oil pressure switch, but I haven't any idea on where to find this. If anyone knows where to locate this or of any other 12v source only when the car is running please let me know.
Any help at all would be really great!!
Thanks,
Tyler
Thanks,
Tyler
Got it all figured out. It just needed a signal wire, not a 12v source, so I just tapped into the oil pressure sensor wire and everything works as it should. I am just running my markers as my DRL's, though with the stock bulb, they aren't all that bright. Anyone suggest any wattage bulb that would be good for DRL's?
Thanks,
Tyler
Thanks,
Tyler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone »</TD></TR><TR><TD CLASS="quote">how bout the stereo? isnt the yellow wire remote???? </TD></TR></TABLE>
That would have been a good bet, but OEM stereo wires aren't colored like aftermarket ones. Gotta get a pinout for that "tyrone".
dreed2300
Jan 21, 2006 06:39 PM
