Honda S2000 Honda S2000
100 ocatens did the same! HELP!
Old Sep 23, 2004 | 02:02 AM
NorthCyprus's Avatar
Default 100 ocatens did the same! HELP!
I don't know why, but i'm sure it's related wit either fuel, or air,
my s2k has a problem which really pisses me off, please help me to solve this problem. When i first brought the car i didnt notice bacause it was my first s2k, my car sometimes looses a lot of horsepower. Imagine i start the car, everything normal, drive it for 20 mins, still normal, than suddenly i try to accelerate like in the 2nd gear in 3000rpm, i press the pedal, the car doesnt response, feels like the car is drowning, then it responses and everythings normal again, then it does it again and again, it really looses power. I tried 100 octanes fuel, i tried injector cleaner (once), no difference. What is this? what should i do? please help me !?!
Old Sep 23, 2004 | 11:16 AM
Kenso's Avatar
HT White Ops
Default Re: 100 ocatens did the same! HELP! (NorthCyprus)
My sister's 2000 S2K had a similar problem, it turned out to be a faulty MAP sensor.
Old Sep 23, 2004 | 01:05 PM
Nishant's Avatar
Default Re: 100 ocatens did the same! HELP! (Kenso)
i had a similiar problem once, no power between 1500-4000rpms, turned out to be my spark plugs
Old Sep 23, 2004 | 01:34 PM
profpin's Avatar
Default Re: 100 ocatens did the same! HELP! (Nishant)
do you get a cel??
Old Sep 25, 2004 | 05:29 AM
Default Re: 100 ocatens did the same! HELP! (profpin)
what do you mean by cel?
Old Sep 25, 2004 | 06:17 AM
Nikos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthCyprus &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by cel? </TD></TR></TABLE>
That is the when the check engine light comes on to show you a malfuction code.
By the way, I see you are from North Cyprus. Interesting considering I am greek
Old Sep 25, 2004 | 06:27 AM
Default Re: 100 ocatens did the same! HELP! (Nikos)
Thanks Nikos, no i didnt get a check engine light, everythings normal with the car except this problem which is driving me crazy, i heared it might be spark plugs, what else it might be if it's not spark plugs?
Old Sep 25, 2004 | 09:59 AM
evil vapor's Avatar
tap the map sensor, it's the black sensor on top of the throttle body, see if that works. If not, it wouldn't hurt to have your spark plugs checked to make sure they aren't loose and nothings "missing"
punk_0333
Jul 17, 2010 10:28 AM
TiMiD703
May 15, 2007 08:59 AM
NorthCyprusAgain
Honda S2000
24
Nov 17, 2004 07:22 PM
01itr320
Jul 26, 2004 08:20 AM
gsr camel
Mar 17, 2002 07:44 PM
