Wow, this is irritating!!
Old Sep 6, 2005 | 02:27 PM
jdmh22luda's Avatar
Default Wow, this is irritating!!
93 obd1 jdmh22...For some strange reason my car will turn over and then just shut itself off. It has been an intermittent problem for awhile mainly b/c I would just push around the dist. until the car would finally start. I eventually found out there was a bolt missing from the dist., and i replaced it. The car ran fine for a week and now it hasnt moved for a couple days and im so angry. I kno it has to be an ignition problem. Alternator is fine, battery is charged, new spark plugs, nology hot wires r 1 1/2yrs old(didnt think they would need replacing). I am completely stumped and do not kno what to do. New distributor or just a cap and rotor? Such an intermittent problem so makes me think its just a loose connection possibly? Plz guys, i need your help!!!!!
Old Sep 6, 2005 | 02:34 PM
stringcheese840's Avatar
Default Re: Wow, this is irritating!! (jdmh22luda)
it might be the electical part of the ignition switch i had the problem about 2 months ago. If you search you should be able to find something on the site I did when i had my problem.
Old Sep 6, 2005 | 02:55 PM
BlueLude94's Avatar
Default Re: Wow, this is irritating!! (stringcheese840)
Have you pulled the dist. cap off, the rotor button may be gone, sometimes the screw that holds the button on will back itself out
Old Sep 6, 2005 | 03:53 PM
jdmh22luda's Avatar
Default Re: Wow, this is irritating!! (BlueLude94)
ya, could u post a pic of exactly which holes your talking about
Old Sep 6, 2005 | 08:31 PM
Altilude's Avatar
has pgm-fi main relay written all over it... search for topics about it...
Old Sep 7, 2005 | 11:06 AM
jdmh22luda's Avatar
Default Re: Wow, this is irritating!! (Altilude)
the main relay wasnt an intermittent problem i thought
Old Sep 7, 2005 | 12:15 PM
connvict's Avatar
Engine ground connection problem..........
Old Sep 7, 2005 | 12:50 PM
eric416's Avatar
Default Re: (connvict)
the main relay usually is intermittent, i'd replace that first. I had the same problem and replacing it fixed my problem
Old Sep 7, 2005 | 09:06 PM
phateless's Avatar
coil/igniter? i say get to testing because you can throw $200-$300 in parts at this thing and get nowhere if you're not sure where to go...
GuitarPunk015
Jun 25, 2009 03:24 PM
nickmcpher
Jul 30, 2008 02:48 PM
NYSItuner
Sep 16, 2007 10:08 PM
dylokjai
Dec 10, 2004 05:08 AM
Pwolf
Feb 9, 2004 05:33 PM
