Wont start
Old Mar 9, 2013 | 05:26 PM
Preludeshbb6200's Avatar
Default Wont start
While my prelude was running I had my hood open beacuse I installed new battery and As I was sitting in the car Iwas looking at the battery and I seen sparks from the positive wire or the battery and my car died . so I went to check it out the positive touche the intake and frame .(bought the wrong battery so the claps where on the side not on the top.)and my car wont start has spark feul pump good coil good compression good Ichecked the *** boxes all the fuses are good what can the problem be ?
Old Mar 9, 2013 | 06:40 PM
thirsk66's Avatar
Default Re: Wont start
you blew your IG or ignition 50A fuse in the under hood fuse box I have done this once and that fuse almost always goes out. Check it and get back to us. Here is the pic of what fuse I am referring to circled in red:
Old Mar 10, 2013 | 05:57 AM
But the fuse seems good
Old Mar 10, 2013 | 11:03 AM
thirsk66's Avatar
Seems good or is good? did you take a long good look at to make sure its intact and not broken in the center? Its either this fuse or another fuse in your interior fuse box like the other ignition fuse or something in there.
Old Mar 10, 2013 | 11:41 AM
I took the fuse out and its not burned and I checkeed all my fuses under the dash and non are burn
Old Mar 10, 2013 | 01:11 PM
Bouckaroo's Avatar
if you didnt blow any fuses then i would be concerend with the ecu. Try borrowing another ecu to make sure you didnt fry yours. I have done this once wheni was trying to boost a car, i shorted it out and it freid the ecu.
Old Mar 10, 2013 | 02:06 PM
Did u get new evil after or you bought it used and how much do they cost
Ecu*
Old Mar 10, 2013 | 02:23 PM
Bouckaroo's Avatar
It was in an accord and at the time i got a repalcment ecu from a breaker for 75 bucks. Depending on what ecu you need they can range form 50 to 300 bucks.
What ecu are you using?
Old Mar 10, 2013 | 08:59 PM
thirsk66's Avatar
If you need an obd2 ECU I have one for you, just let me know.
Old Mar 13, 2013 | 08:43 AM
how much you asking for it?
Old Mar 13, 2013 | 09:44 AM
thirsk66's Avatar
I paid a bit of money for it and only used it twice to run my car, it does not have the immobilizer in it so it will start and run any prelude with a obd2a ecu plug ins and an h22a engine of course.
Old Mar 14, 2013 | 01:12 PM
How much
Old Mar 16, 2013 | 06:59 AM
thirsk66's Avatar
Just make me an offer on it, it is a JDM ecu so might be what your looking for
Old Mar 17, 2013 | 10:04 AM
Is that a obd2a or obd2b
Old Mar 17, 2013 | 11:27 AM
thirsk66's Avatar
obd2a
freewealthana
Jun 22, 2017 11:07 PM
Crocky
Apr 19, 2017 11:03 AM
turbo-crx
10
Jan 17, 2009 01:46 PM
LudeNsoL
Nov 19, 2007 08:55 AM
