Where are the timing marks?
Old Jul 11, 2003 | 08:07 PM
Weston's Avatar
Default Where are the timing marks?
Does anyone know where the timing marks are on a 1990 Prelude 2.0 Si? That's the B20A5 engine. I don't see an arrow or colored marks like my Integra.
Old Jul 11, 2003 | 09:30 PM
4bidden's Avatar
Default Re: Where are the timing marks? (Weston)
I dont know much about 3gen ludes, but if its like the 4gen and 5gen then its on the flywheel, not the crank pulley like youre probably used to.
Old Jul 12, 2003 | 12:23 AM
gulf imports
Guest
Posts: n/a
Default Re: Where are the timing marks? (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">I dont know much about 3gen ludes, but if its like the 4gen and 5gen then its on the flywheel, not the crank pulley like youre probably used to.</TD></TR></TABLE>
what is the best way to put a 4 gen in time?
Old Jul 12, 2003 | 12:41 AM
4bidden's Avatar
Default Re: Where are the timing marks? (gulf imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gulf imports &raquo;</TD></TR><TR><TD CLASS="quote">
what is the best way to put a 4 gen in time?</TD></TR></TABLE>
What??
Old Jul 12, 2003 | 09:13 AM
h22a193's Avatar
i think he mean how do you check the timing properly with the 4g ? I did mine and Im still worried that I messed up cause I never could find the plug your supposed to block off under the dash. Where is that?
Old Jul 12, 2003 | 09:15 AM
Elkins911's Avatar
Default Re: (h22a193)
should be somewhere close to the ecu on the passanger side.
whats this about timing on a h22a??? where do we check it at?
Old Jul 12, 2003 | 10:47 AM
4bidden's Avatar
Default Re: (Elkins911)
The ECU jumper is behing the center console near the gas pedal. It is blue in color. Here is a picture.
You are supposed to jump that before you mess with your distributor timing so it "blinds" the ECU.
You need a timing light to check your timing.
Old Jul 12, 2003 | 10:58 AM
h22a193's Avatar
thanks 4bidden, going to go do it right now!
Old Jul 12, 2003 | 11:10 AM
4bidden's Avatar
Youve got a timing light I assume then?
Old Jul 12, 2003 | 11:25 AM
h22a193's Avatar
yes I do, where are the plugs, I cant find them
Old Jul 12, 2003 | 11:31 AM
4bidden's Avatar
What plugs do you speak of? The ECU jumper is behind the center console on the drivers side. Reach behind there, they might be plugged into a dead end connector, just unplug it from there and you're good to go.
This location is for 4gen.
Old Jul 12, 2003 | 11:40 AM
h22a193's Avatar
i only found 2 blue connectors, there go to a dead conection on that metal braket?
Old Jul 12, 2003 | 11:41 AM
h22a193's Avatar
I cant find that grey one you have in the pic
Old Jul 12, 2003 | 11:47 AM
h22a193's Avatar
found it, HELMS!
4bidden's Avatar
You need the blue one with 2 holes.
Old Jul 12, 2003 | 01:04 PM
h22a193's Avatar
Checked timing, got the line on the flywheel right above the arrow that you line the dot up with. I dont know how many degrees this is, bt its prob just 1, cause its really close to lining up, just slightly advanced
hondaPOWERD
Dec 2, 2007 04:24 PM
Type-GS-R-Turbo
Dec 31, 2004 05:43 AM
NobodysHero
May 1, 2004 11:32 AM
dvp95
Aug 21, 2003 07:45 AM
boomslang
Nov 30, 2001 06:48 AM
