wheel spacer
okay so i've bought a set of 15" type r rims for my 4th gen. I know i need wheel spacers up front but im not sure what size. Will any brand wheel spacer be sufficient? Any brand name suggestions? Also, should i go ahead and put spacers on the back wheels to even it all out?
im not sure what the offset is on the wheels are, but if you get spacers, make sure you get spacer that will fit hondas, if you look on ur rotors, the center tapers out, so when looking for spacer make sure the back of the spacers taper in and the fronts tapers out. also depending how thick the spacers are, you might need stud extenders. BIGGEST THING IS TO FIND OUT THE OFFSET OF YOUR WHEELS AND THEN CHECK THE OFFSET ON THE LUDE, FIND DIFFERENCE IN OFFSET, AND DATS THE MINIMUM SIZE U NEED. as for getting them for the back if the offset isn't deep enough then yes you need them for the back too. but if the wheels offset are deep enough then its ur call, i would just to make the stance look more copecedited. check tirerack.com. Go get HONDA TUNING for this month, good ariticle on offset, also prelude on cover.
