What header is this?
Old Aug 17, 2004 | 11:15 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default What header is this?
I recieved this from a honda-tech member (it's the one on the bottom, being compared for length to the DC h23 header and the stock h23 header). It was advertised as an obd1 jdm h22 header. Why is it so short? It's missing the flex pipe section which makes it about 18 inches too short. The header that came with my swap looked different; it did not have a donut thing installed before the flex pipe (which was cut off). What kinda header is this? I held up the h22 gasket and it lines up perfectly. I'm thinking that this may be an obd2 header or something.
Old Aug 18, 2004 | 05:33 AM
Silverpike's Avatar
Default Re: What header is this? (PreIudeSI)
It is definitely an OBD1 header, because all OBD1 style headers use donut joints instead of flex joints. It is just missing a piece actually, that is why it is too short. There should be one more piece (a C-pipe) that has another donut flange on one end and the cat flange on the other. My Fujitsubo header for the 4th gen is like this. The C-pipe is just a straight piece of tubing; you could fabricate one if you wanted.
Old Aug 20, 2004 | 07:44 AM
PirateMcFred's Avatar
Default Re: What header is this? (Silverpike)
I have owned 2 4th gen 1993 Preludes (both OBD-1) and neither of them had a donut style header coupling. Looks stock to me and like somebody just hacked off the flexpipe and put a donut coupler on the end of the pipe.
Pirate
Old Aug 20, 2004 | 05:24 PM
PreIudeSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverpike &raquo;</TD></TR><TR><TD CLASS="quote">It is definitely an OBD1 header, because all OBD1 style headers use donut joints instead of flex joints. It is just missing a piece actually, that is why it is too short. There should be one more piece (a C-pipe) that has another donut flange on one end and the cat flange on the other. My Fujitsubo header for the 4th gen is like this. The C-pipe is just a straight piece of tubing; you could fabricate one if you wanted.
wrong, stop talking out of your ***. I just showed you pics of 2 obd1 headers that are NOT donut style.
Old Aug 20, 2004 | 05:33 PM
Nikoli's Avatar
deffinately looks like someone did cutting on it. every honda header i have came with flexpipe on it
btw: are you trying to use that on an h23?
Old Aug 20, 2004 | 07:04 PM
egizzle8
Guest
Posts: n/a
Default Re: What header is this? (Deckedlude)
1 O2 bung = obd1
2 O2 bungs =obd2
Old Aug 20, 2004 | 10:59 PM
PreludeRacer023's Avatar
Default Re: What header is this? (egizzle6)
the only headers ive seen that use donuts are b series, they use those spring bolts instead of flexpipes, all H series headers have a flex pipe...its either a b series header, or a hacked up hone if you say the upper part fits, i dont think a bseries header will line up on an hseries, but im sire no one has ever looked, maybe they do line up on the head..lmao
Old Aug 21, 2004 | 01:42 AM
PreIudeSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">1 O2 bung = obd1
2 O2 bungs =obd2</TD></TR></TABLE>
WRONG, on obd2 cars, there is an o2 sensor before the cat (in the header) and one after the car (not on the header). C'mon people.
I was trying to put it in my h22 swapped prelude but it doesn't work out obviously. I could have taken it to a muffler shop and had a section made for it but i wanted to avoid the trip to the muffler shop and i didn't want to pay xx.xx for something that should have been right to begin with.
I'm trying to get a refund from the h-t member who sold it to me but he seems to think that he's right, even thugh what i bought was an obd1 header for the h22 that would fit my prelude. He says it came with his swap from hmotors.
I think it's a header for a h22 into a civic chassis. Maybe i'll check over in the hybrid forum.
1994PreludeSi
Sep 12, 2007 09:08 PM
VTecLude1994
Sep 25, 2005 03:24 PM
caLiH22A
Sep 28, 2003 12:33 AM
ITR 01-0840
Apr 25, 2002 05:01 PM
