what could it be????
1994 h22 prelude, smokes alittle, black stuff is shot on the ground out of exhuast, still has original spark plugs and wires, took a plug out and the whole tip was white. what is wrong?
thanks in advance
thanks in advance
Usually a plug that is White at the tip is burning too hot, are the plugs the correct heat range ? Might be time to replace plugs anyway if as you say they are originals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22 VTEC »</TD></TR><TR><TD CLASS="quote">still has original spark plugs and wires
thanks in advance</TD></TR></TABLE>
from a 94?? damn, buy some plugs dude....... and wires FAST
and stop running 87 octane, it may be screwing up your mix/ignition
i just got the car, just spent 800 on timing belt/water pump/rotors. and i run nothing less than 92 octane...so what spark plugs should i get? will that take care of my prob
deftones0817
13
Jun 27, 2004 12:35 PM
