vtec grind metalic sound?
Old Jun 19, 2007 | 06:38 PM
slickshifter's Avatar
Default vtec grind metalic sound?
When the cam profile changes around 4500rpm there's this metalic grind sound for a second. What could this possibly be? thanks
Old Jun 19, 2007 | 08:29 PM
P13_mein's Avatar
Default Re: vtec grind metalic sound? (slickshifter)
before the switch over? @ 4500?
or do have a controller?
Old Jun 19, 2007 | 11:34 PM
exactly at 4500. Just checked the oil and it's fine. thanks for your help.
Old Jun 20, 2007 | 10:07 AM
bump please anyone
Old Jun 20, 2007 | 12:33 PM
preludestud11's Avatar
Default Re: (slickshifter)
you shouldnt have vtec change over until around 5200 unless you have a differnt ecu or some kind of vtec controller. have you pulled the valve cover to chekc the cam lobes?
Old Jun 20, 2007 | 01:00 PM
93sivtec's Avatar
I would definately open that up and inspect....metallic sounds are never good coming from the engine.It dosent make any sounds except for that point?Do u have aftermarket cams?
Old Jun 20, 2007 | 07:03 PM
It's right when the cam profile changes at 4500, stock everything. 5200 is when the extra intake butterflys open and allow more air in not when it switches to the higher profile cam lobe from my understanding. I called a honda shop and they said that it might be the oil filter being clogged going to the silinoid that lifts the cam. I'm getting it fixed tuesday whatever it is. It sucks because I just got my skunk2 exhaust and getting it installed tomorrow, so I can't test vtec w/ it. I'll let you guys know what it is after it's fixed.
Old Jun 20, 2007 | 10:25 PM
P13_mein's Avatar
well you're wrong
unless you have a GSR;
lift the valve cover and inspect
an interference with the butterflies which open @ 4400 doesn't sound like a grinding,more like a tapping sound
Old Jun 21, 2007 | 12:02 PM
Well it's right at 4400 or 4500 and then the grind stops so I have no idea.
Old Jun 21, 2007 | 01:40 PM
doesn't make the sound in first only second. WTF
Old Jun 21, 2007 | 11:13 PM
bump
Old Jun 22, 2007 | 01:32 PM
Wow I guess I stumped everyone
Old Jun 22, 2007 | 02:14 PM
godslayer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slickshifter &raquo;</TD></TR><TR><TD CLASS="quote">Wow I guess I stumped everyone</TD></TR></TABLE>
Lol.....my phone is ringing and I need some help. Can someone on the internet please tell me who it is now?
It's been said about a dozen times to pull the valve cover & check for proper clearances but if it's only happening in a certain gear I'd think it to be tranny related.
Old Jun 22, 2007 | 02:32 PM
93sivtec's Avatar
No doubt.....if it only happens in 1 gear I would agree its probally tranny related,but if not it takes about 10 min to take the valve cover.
Old Jun 23, 2007 | 11:03 AM
Changed the oil and put royal purple 10-30 in and the problem was solved. I think the previous owner must have used too thin of oil. I'm so relieved. thanks for the help guys.
Old Jun 23, 2007 | 02:04 PM
wegotmorrison's Avatar
The previous owner probably had the oil changed at Wal Mart or something.
Old Jun 23, 2007 | 03:03 PM
mantis92gsr's Avatar
Didn't you know, thats how V-TAK sounds when it kicks in.
Modified by mantis92gsr at 6:17 PM 6/23/2007
Old Jun 23, 2007 | 03:19 PM
mafia's Avatar
Default Re: vtec grind metalic sound? (mantis92gsr)
Im have same problem... Im using 5W30 cheap oil from napa (thinking of using just for a month). So should i change oil to 5W30 synthetic oil or 10W30 synthetic oil? Or just do a valve ajustment?
Note, this is on my project car that i just got runing. (bought with ripped timing belt, didnt know)
Old Jun 24, 2007 | 10:53 PM
i switched to royal purple 10W30, problem solved
D-Rob
Engine Management and Tuning
Apr 14, 2008 11:39 PM
Jap_Spec_Imports
Apr 13, 2008 09:47 PM
Nikos
Apr 27, 2004 10:22 AM
cr-x si
Aug 3, 2002 08:43 PM
