Upgrading CAMS
Old Feb 12, 2013 | 08:39 AM
Danny Fallas's Avatar
Default Upgrading CAMS
So I saw an opportunity of getting the Brian Crower cams Stage 3 + forged valve springs.
I don't have a lot of money, but I think i will buy this. But is it safe to run BS S3 with oem H22a1 retainers?
Thanks.
Old Feb 13, 2013 | 01:32 PM
slowredsol's Avatar
Default Re: Upgrading CAMS
no. you will need to get aftermarket retainers also. The retainers give you more clearance that is needed with larger cams.
Old Feb 13, 2013 | 03:30 PM
98vtec's Avatar
moderator emeritus
if you dont have a lot of money, you dont need to dive in that deep.
other things you need to consider is tuning.
hardware can easily run you 400+ dollars plus the tuning expense which can range anywhere from 250-550. How about cam gears to effectively make use of these cams (they will need to be moved in order to make good power).
cleanep3
Jun 15, 2010 06:12 AM
bsmith100
Jun 12, 2008 04:42 PM
djvtoner
Oct 28, 2004 09:32 AM
LiveWire401
May 9, 2003 09:32 AM
