Unique Swap
so im thinking bout undertaking my first true swap by myself into my prelude and wondered if anyone could give me some info on wat i might need to get or do to make this kinda of a unique swap accomplished
the engine is a 4g63t i have running 15psi of boost that is currently in my 89 dodge colt gt
the plan to transplant that into my 92 honda prelude s with a little bit more engine work
i do have everything such as ecu harness tranny transaxles and i think bout everything i need except engine mounts and the exhaust setup
but anyone with engine swap experiences help would be nice and any suggestions on anything i could do or need to get let me know
4g63t more work than ls1 rwd engine lol i doubt that since it can be a fwd setup and i have the full setup with two harnesses two ecus front drive shafts and whole brake setup
exactly.
my buddy just finished this conversion but he did it ina bubble he used the entire drive train out of and evo and it was a ton of work he had to cut the k frames apart use part evo part civic fire wall has to be cut open with the whole floor and he had to move the rear strut towers back and inch and half if you made it front wheel drive it is very easy to put in it would like be puttin a k in
No problem u should def do it it's such a cool swap and u can make tons of power easily my buddys made 800 in the Evo he's gunna run it at like 500 should be tons of fun in a awd bubble!!!
Always talking about his low post count.
Lol
Anyway. This swap will be good to see done.
