Tyre Pressure
Old Jan 5, 2002 | 10:04 AM
skyline69's Avatar
New User
From: Craigavon, Co. Armagh, Northern Ireland, Northern Ireland
Default Tyre Pressure
Can anyone tell me the correct tyre pressure (front and back) for a 4th
Generation Prelude 4WS 2.2 VTEC with 17in Rims with 205x40% profile tyres
as different mechanics keep telling different psi's! I know it is different
from recommended as the profile and wheel size has changed. Any ideas?
Brian
Old Jan 5, 2002 | 10:53 AM
Sigma D's Avatar
Default Re: Tyre Pressure (skyline69)
good tire pressure is 32 to 35 psi
Old Jan 5, 2002 | 11:41 AM
Defiant1999's Avatar
if your running a low profile tire you should always run a lot higher pressure, Im running 42-43lbs in my fronts and 38lbs in the rear (225x35-18). I have talked to a bunch of people about the suggested tire pressue and everyone has said to run higher pressure. I have Toyo Proxi tires and 3 of them have split on the inside side wall and running to low air pressure (32-35) is what caused it.
Old Jan 5, 2002 | 11:51 AM
Sigma D's Avatar
Default Re: Tyre Pressure (#1lude)
sweet
Old Jan 5, 2002 | 11:52 AM
Mike95lude's Avatar
I agree with #1 Lude.
Old Jan 5, 2002 | 04:00 PM
vpforeva's Avatar
New User
Default Re: Tyre Pressure (Mike95lude)
um isnt the tire pressure imprinted on the tire? mine says 60 psi max, so i run like 40 psi
Old Jan 5, 2002 | 04:03 PM
nicksweetlude's Avatar
Default Re: Tyre Pressure (vpforeva)
my max on my 215/40/17 is 50 which is what the tire place had it aired up to but i let it down to 40 all around. so i would go with 36-40 or maybe 42 but not any higher
91akira
Sep 15, 2009 04:25 PM
benji7288
Nov 21, 2007 01:21 PM
SkRiBLaH
10
Feb 16, 2004 09:25 AM
silverCRXTC
Jun 1, 2003 10:02 PM
MooreBoost
Sep 5, 2002 03:26 PM
