type s engine swap
Old Jun 30, 2004 | 09:23 PM
snuff_prelude's Avatar
Default type s engine swap
is it possible to swap out a type s engine for a v-tech in a 92 prelude, and how much would that cost
Old Jul 1, 2004 | 08:37 PM
Default Re: type s engine swap (snuff_prelude)
bump
Old Jul 1, 2004 | 09:45 PM
Speedra500's Avatar
type-s engines are very costly and not wort the 20 extra hp, at least IMO. You can probably get a motor and tranny and ecu and all that for around 1800 or so
Old Jul 1, 2004 | 09:58 PM
Behan's Avatar
Default Re: type s engine swap (Speedra500)
I'm guessing you have an "s" model usdm prelude. That is not referred to as a "type-s".
But to answer your question, yes you can swap in an H22 (its spelled vtec,
not v-tech. thats a phone ) You should be able to get the swap done for under $3000.00
Old Jul 2, 2004 | 12:26 AM
@ries's Avatar
Yes it's possible... unless you are getting the motor for dirt cheap why not consider the Euro-R motor instead?
Old Jul 2, 2004 | 04:01 AM
eLuderTypeS's Avatar
Yes it is possible, but for the money you spend on the type s engine you could make mroe power with a mildly built H22A
Two cents
Old Jul 2, 2004 | 04:48 AM
Spocko's Avatar
Default Re: type s engine swap (Nine4ourSedan)
If you go this route like I did > forget the type-S setup and get the JDM Euro Accord-R H22a setup instead > same engine as type-S, better intake manifold, and the best tranny made for H22's (not to mention comes with a LSD as well, not ATTS )
dtownrex
Aug 28, 2010 01:59 PM
Chukkie
Oct 25, 2006 08:09 PM
DJ Synergy
Nov 3, 2004 09:57 AM
Brandon
Dec 1, 2002 07:08 AM
Chronic139
Dec 6, 2001 07:33 PM
