tuning necessary?
Old Apr 20, 2009 | 07:48 PM
Inextricabledrvr's Avatar
Default tuning necessary?
I recently changed my muffler from an APEXI WS to an EVO2 muffler. As well as correcting the leak in my header. About 2 or 3 years ago I got my cars A/F ratio corrected by getting it tuned.
Would you guys recommend me getting it retuned due to the new modifications I added/ccorrected. I just wanted to know if its worth it. I have listed the minor boltons below.
Current Mods: Intake, dc header w/ 2.5" collector, high flow cat, Greddy evo2 custom 2.5" piping, FPR, and pulleys.
Thanks guys
Old Apr 20, 2009 | 10:07 PM
Kronn 98SH's Avatar
Default Re: tuning necessary?
I'd get a dyno pull with A/F ratio. That should tell you if it needs adjusted.
Old Apr 20, 2009 | 11:07 PM
dagle's Avatar
no... minimal change if any at all.
Old Apr 21, 2009 | 02:50 PM
1GPlusSH's Avatar
ditto
Old Apr 21, 2009 | 02:51 PM
1GPlusSH's Avatar
and what's with all these preludes running 2.5" exhaust??
Old Apr 21, 2009 | 02:54 PM
Kronn 98SH's Avatar
It's dyno-proven that the Prelude makes more power with 2.5" piping versus the stock 2.0" piping.
Old Apr 21, 2009 | 03:36 PM
kulrevon's Avatar
was the leak in the header before or after the O2 sensor? how bad was the leak? and how are you tuning the air/fuel?
Old Apr 21, 2009 | 04:01 PM
The leak was on the top half of the header and yes the leak was pretty bad. there were leaks in 3 different places. I was planning on getting it dynotuned to correct it if necessary.
Old Apr 21, 2009 | 04:06 PM
1GPlusSH's Avatar
I gained horsepower when I went from 2.5" to 2.36(60mm). For a basically stock prelude, 2.5" is too much is what I was trying to say.
Old Apr 21, 2009 | 04:34 PM
gstrudler's Avatar
go check the threads on 3" exhausts. several people have made gains across the board going to 3" from 2.5" on mildly built n/a motors. so it makes me curious that you apparently gained power going to a smaller size.
Old Apr 21, 2009 | 04:35 PM
Kronn 98SH's Avatar
And what I'm trying to say is that even with a bone-stock Prelude, it still makes more power with 2.5" piping. Hell, there are dynos out there showing that 3.0" piping made power over stock. However, you might lose 1-2hp down low.
Old Apr 21, 2009 | 05:05 PM
1GPlusSH's Avatar
I guess threads like that are why all these slower than stock civics are running around town with blaring exhaust. I just don't see how those who got more horsepower didn't have more interference with the exhaust waves. So how big is too big? 3" is for 300hp+ but somehow isn't hurting 170whp preludes...why not go to 4"?
Old Apr 21, 2009 | 05:08 PM
1GPlusSH's Avatar
I'll agree with that. I have just seen a LOT of threads lately with these preludes pushing 190whp tops with 2.5" exhaust. Who knows, maybe all of them are going to get up in the power ranges where 2.5" is ideal.
Old Apr 21, 2009 | 10:48 PM
Kronn 98SH's Avatar
It was in the FAQ. Here ya go. (and no loss down low)
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/3%22-catback-exhaust-stock-jdm-h22a-dyno-2197695/
Old Apr 21, 2009 | 11:47 PM
1GPlusSH's Avatar
I would like to see a mandrel bent 3" dyno for that car. Even still, he probably still had at least 2.5" at the bends and gained. I would like to see the write ups on flow after the collector. Maybe I need to do a little more research. Thanks, Kronn.
Old Apr 22, 2009 | 12:40 AM
Kronn 98SH's Avatar
yw
Old Apr 25, 2009 | 09:16 PM
Correct me if im wrong, but when a car is running rich does the bumper start turning black? Black I mean there are black carbon deposits all over my bumper. I made a drive to san diego yesterday and noticed my bumper was covered in soot.
The soot that covered my bumper started happening after I fixed my leaking header as well as changing my WS I muffler to an EVO2 muffler.
Tuning necessary?
Old Apr 25, 2009 | 11:00 PM
gstrudler's Avatar
classic symptom. yeah, it's likely hydrocarbons (unburned fuel). trying leaning it out a little.
Old Apr 26, 2009 | 04:58 AM
Is there anyway I can do it myself? or should I just get it dynotuned? I do have a FPR and guage, but my guage went out on me.:/
Old Apr 26, 2009 | 05:16 AM
mattsnooz's Avatar
LOL. Get rid of that cheap aftermarket FPR than. Better off with your stock oem fpr.
You either get a wideband and a means to register your A/F ratio or you go to a dyno shop where they have all the equipment to do it.
Widebands are expensive (for the ones that are accurate enough to base your whole tuning setup off of) so a shop might be your best option.
Your tuned already ie. have programable ecu/ chip (or however you went) so a retune/reflash shouldn't be that expensive especially if you go to the same shop. I couldn't see it being more than an hour of the shops time maybe two(hope not). It would just be fine tuning.
Old Apr 26, 2009 | 10:51 PM
I will get it dynotuned asap. Anyone know of any Dynodays coming up in southern cali?
As for the "cheap aftermarket FPR". The shop that installed it for me told me "i needed it to get a better tune". Obviously the stock FPR is more than enough for my minor boltons. This was over 3 years ago, and now I know that the stock FPR is much better than any aftermarket. Thanks for the input
Omega Blaze
Jan 24, 2011 04:42 PM
$amGD3
12
Sep 21, 2010 10:39 AM
bokboked
Jun 3, 2007 01:35 PM
Ninjaboi_on_X
Nov 4, 2003 01:35 PM
