tranny question
hey people is it normal to feel the gears when changing?
i just got a new clutch and after its worn in i can feel it going into the gears, nothing too bad but just wondering if its normal
probably have to bleed the lines for the clutch master cylinder. or try adjusting the pedal engagement. sounds like your clutch isnt fully disengaging. oooorrrrr your syncros are gone. and because of the new clutch you can fell it more. but that shouldnt be the case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">Deff not normal. Check your tranny fluid as far as the level and... make sure its honda MTF.</TD></TR></TABLE>
ok how do i check my cluch fluid..
it doesnt crunch or anything i just feel it going into my gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon »</TD></TR><TR><TD CLASS="quote">probably have to bleed the lines for the clutch master cylinder. or try adjusting the pedal engagement. sounds like your clutch isnt fully disengaging. oooorrrrr your syncros are gone. and because of the new clutch you can fell it more. but that shouldnt be the case.</TD></TR></TABLE>
adjusting the pedal engadgment, would that matter as i just adjusted it to grab
down lowclose to the floor as its was grabbing high
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_crazy »</TD></TR><TR><TD CLASS="quote">
Well your asking two different things. To check your clutch fluid, check the clutch master cylinder under the hood(drivers side firewall) make sure it has fluid in it(DOT3). To check the trans fluid pullout the fill holeplug on the tranny on a level platform it should be lever with the hole. I like to over fill mine and put the plug in when it still dripping just to be on the safe side.
i know about the clutch and i checked it and it was just under max so i topped it off.
But about the tranny im not excatly getting how to check it. sorry about this.
do i have to go under the car etc..
</TD></TR></TABLE>i know about the clutch and i checked it and it was just under max so i topped it off.
lisajasmin
Jun 4, 2008 04:56 PM
