tranny problem
Old Jun 21, 2008 | 06:24 AM
DSMkiller's Avatar
Default tranny problem
Hi guys I have a problem with my H22a tranny.. when I put the fifth gear I ear a strange noise.. like the synchro are finish.. do you think I can adjust the cable from the shifter??
thanks
Old Jun 22, 2008 | 05:29 AM
vtecb18c's Avatar
Default Re: tranny problem (DSMkiller)
does it pop out of gear when your driving?
Old Jun 22, 2008 | 12:12 PM
95JDMprelude's Avatar
the prelude is notorious for tearing up synchros mainly 3rd and 5th first u will hear a weird noise then it will start grinding then it will start to pop out of gear and then it wont go into gear at all...ur probably lookin at a tranny rebuild or buyin a tranny...id buy one with the m2b4 code with it has a LSD...and if u decide to buy one with LSD make sure u look where the cv joints go in if u and see all the way thru its LSD if theres a pin in the way then its not
Old Jun 22, 2008 | 07:14 PM
DSMkiller's Avatar
No the gear do not pop out.. and My tranny is LSD.. so probably I will rebuild it..
but you guys are sure it canot be only the cable
Old Jun 23, 2008 | 04:21 PM
Default Re: (DSMkiller)
if its the synchros then it wil get worse over time...u can adjust the cable if u think it may help ive never heard of the cable doing that but it doesnt hurt to try
soloef8ef9
14
Oct 17, 2011 04:13 AM
ADAMnQuickRDX
Transmission & Drivetrain
Jun 30, 2009 01:02 PM
hfrex
May 14, 2009 03:20 PM
Skinny_REX
Jan 20, 2006 07:08 AM
B-B-K
May 20, 2004 12:04 AM
