Traction Bars ???
Old Apr 23, 2009 | 10:40 AM
Bmxlambis's Avatar
Default Traction Bars ???
i want to get some traction bars on my 92 lude and i was wondering if their is any diy on this ... ive looked and cant find nothing ... any suggestions on how to do it .... i seen some on ebay for 200 but im not sure how legit they are and it doesnt look to complicated to diy
Old Apr 23, 2009 | 11:27 AM
2.2Lude's Avatar
Default Re: Traction Bars ???
esp i believe makes them for our cars.
Old Apr 23, 2009 | 11:41 AM
Apex1972's Avatar
http://www.explicitspeedperformance.net/TBS.html
just be sure to get your alignment checked after you are done.
Old Apr 23, 2009 | 12:52 PM
Bmxlambis's Avatar
so this will eliminate the cross member and radius rods i take it
Old Apr 23, 2009 | 09:53 PM
HdeucedeuceA's Avatar
The ESP traction bars are great. Worth every penny IMO.
Old Apr 23, 2009 | 10:07 PM
jlude90's Avatar
it will replace them
Old Apr 23, 2009 | 10:08 PM
boostedmonkey's Avatar
Less weight, better handling. It's a win/win. That's what it's all about.
Old Aug 30, 2009 | 04:25 PM
kenny_'s Avatar
It seems to get rid of the center beam bar. Do you jack the car up from the traction bar instead???
Old Aug 30, 2009 | 07:43 PM
lude98SH's Avatar
you can yes
Old Aug 30, 2009 | 08:33 PM
Acidcrakker's Avatar
I would like to see a cheaper traction bar come out. 450 bucks is still alot of money for that.
I still want one thought
Old Aug 30, 2009 | 08:56 PM
jlude90's Avatar
DIY
do some research, its not that hard. Just very time consuming to get it right.
Old Aug 31, 2009 | 01:51 AM
MikeLuder's Avatar
Actually if you replace your radius rod bushings with new rubber or poly, will help a bunch for cheap.
on that note, Poly bushings all the way around, lower & upper control arm bushings help a ton +++
Just them bushings in the lower arm are a b*tch to replace, have to be torched out & pressed in
i'd take an ESP traction bar with front mount, If I could afford it
Old Aug 31, 2009 | 01:25 PM
crazes's Avatar
Moderator
well if you want to be cheap you can go on ebay and look at these if you want to go there
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old Aug 31, 2009 | 02:21 PM
Televator's Avatar
Am I the only one who remembers the one from AV-engineering?
Old Aug 31, 2009 | 11:07 PM
cardudelude's Avatar
Those ebay ones look like crap. Like i have been telling myself if your gunna do the upgrade do it right the first time dont try to find a cheaper way around it. Just save your money and buy the ones from esp
Old Sep 1, 2009 | 01:18 AM
meanshyguy's Avatar
^I don't see a problem with them? It seems to be an exact raplica for a third of the price, it's just welded metal with correct measurements.
Old Sep 1, 2009 | 02:43 AM
The ones on ebay are made in china in sweat shops, thats why they can be so cheap.
Old Sep 1, 2009 | 04:51 AM
NormanBates's Avatar
That, and the heim joints aren't chromoly, the steel probably isn't 1/4" - 3/16", the welds probably aren't the best....I built mine (under $170) but the welder charged $110, and I have to get it powder coated. Take your time, and use common sense. Remember "measure twice, cut once" and you can do it with your basic tools. Maybe I'll post pics.....
Old Sep 1, 2009 | 11:19 AM
jlude90's Avatar
more like measure 18 times, refit, measure 10 more times, refit, measure another 20 times, refit, tack, grind out tack, refit, measure more...refit.
maybe it wasn't that bad in a newer car, but in a 3G with an H its an absolute bitch. I modeled mine after the L-Con bars though, so that took alot longer
Old Sep 2, 2009 | 04:36 AM
LOL! That's exactly how it was! But I wouldn't trade that experience for $450 and someone else's name on my car. My 2 cents.
Old Sep 2, 2009 | 06:49 AM
pentaq's Avatar
How to calculate the angle and the distance from the end of the bar for the radius rods? What kind of material use for the radius rods? Just solid aluminium? What thickness?
Old Sep 2, 2009 | 07:01 AM
A Blue Lude's Avatar
It would be nice if someone actually compared the stiffness of the stock crossmember compared to some of these aftermarket ones.
Old Sep 2, 2009 | 07:16 AM
99JDMHATCH's Avatar
My opinion is traction bars are traction bars, I mean my friend even welded his in his basemen. No more then just three bars that help the car from wheel hop. OP its cake to put them on just remove your oem tow hooks and connect to your control arms. Shouldn't take more then 45mins. The only problem I had was trying to get around my charge pipe.
Old Sep 2, 2009 | 07:20 AM
YZFR6's Avatar
Hey, guy's if anyone one of you guy's are interested. We're looking into making a ProV2 traction bar kit for the Preludes. We're looking candidates to try the product. Please PM me for info. Thanks
Old Sep 2, 2009 | 08:53 AM
A traction bar isn't a crucial part of the suspension of an older Civic. They work just fine without it. The Prelude is different...
