throttle issues? back fire from intake?
Old May 18, 2016 | 07:53 AM
notned22's Avatar
Default throttle issues? back fire from intake?
hey guys i just traded my 95 accord for a 93 lude, with a h22a1 swap. its pretty much stock other than a cai, ngk wires, and exhaust. any ways i know theres a s**t ton of threads out there about the famous (hesitation) .. but im not wondering about that, wich i have but theres a diff problem. so when i start my car it starts fine the rpms jump to about 2k then lower back down, but if i barley hit the throttle the cars atomaticly throttles to 2k stays for like 2 sec then comes down, if your under the hood and throttle it by hand when it jumps you can hear the intake sucking in air the it makes like this poping noise when it comes down.. the throttle body isnt sticking iv tested the tps and changed the senser, it reads 0.5 at idle and 4.5 wop. i cleand the iac, clean the upper mani, lower mani, replaced gaskets to tb, and both manifolds. it almost sounds like somthings getting stuck open for a second or somthin. when it the rpm raises the air gets sucked in from the hole inside the throttle body in the top left and side right before the main butterfly. could a intake valve be sticking? im stumped cant seem to crack this one so i thought id ask help from yall!! any thoughts would be appreciated thanks!
Old May 19, 2016 | 12:25 PM
holmesnmanny's Avatar
Default Re: throttle issues? back fire from intake?
For the first issue, it's caused by not using shielded wire for the knock sensor when someone does a swap. If you look at your knock sensor it's likely you'll see it's regular wire. This allows radio interference to screw up the knock sensor readings at the ecu. It causes the timing to get messed up, causing a jerking/hesitation.
For the second issue can you describe in detail this popping sound ? Does it really sound out of the ordinary ? Can you make a clear detailed video ?
Old Jul 6, 2016 | 08:22 AM
AudioFunk's Avatar
My Prelude has the same problem, if I bearly touch the throttle the idle will rise to like 2k then the intake will "pop"'then the idle will come down. My Preude is swapped and it did it with my old engine and now with the new one, it's pretty annoying because when in gear the idle will be high. It all started 2 years ago when I took It to a mechanic to get the timing belt done on my old engine. If I disconnect the map sensor and turn on the car it won't do the popping noise anymore, but the car runs like crap lol. I tried a new map sensor and didn't fix it, all vacumn lines are routed correctly. I pretty much don't know where else to look so I just left it. Let me know if you get it fixed.
Old Jul 13, 2016 | 04:14 PM
minilogoguy18's Avatar
Check ignition timing and mechanical timing. Backfiring through the intake is caused by a lean running condition, the fuel mixture is being ignited before the spark plug fires and the intake valves have not fully shut. Make sure the fuel is OK, gas is cheap now a days, it wouldn't hurt to drain the fuel and put fresh 93 in it. There is a drain bolt on the tank on the drivers side towards the back of the tank, it takes a 17mm wrench and has a sealing washer similar to one used for the oil drain bolt.
Orie Bethel
Mar 7, 2016 10:02 AM
silverdcteg
May 16, 2011 07:30 AM
97ekjose
May 22, 2010 06:44 PM
memorybox
Sep 19, 2006 11:07 AM
NeoGSR
Feb 9, 2003 08:09 PM
