Thermostat help
Old Jan 26, 2006 | 05:38 PM
wrx'n you's Avatar
Default Thermostat help
Can someone please tell me what the differences between the Mugen Thermostat and the OEM thermostat is? The only thing i know is that the Mugen one opens up at 80 degrees. Is it alright to use for a built h22 daily driven? thanks
Old Jan 26, 2006 | 05:41 PM
The Weather Man's Avatar
NO. DO NOT GET THAT.
Unless you're drag racing the car that is a STUPID thing to do.
No car runs efficient UNLESS it is at optimum temperature. To run efficiently, a car must burn off all gasses.
Don't get it. Period. You'll just hurt performance in the outcome. The factory cooling system is efficient enough.
If you want to keep your car cooler - just make a fan switch. But that would be piontless because when driving at highway speeds- the air is cool enough.
Even if its 90 degress outside, you have to think about the chill factor at 70MPH.
If you buy an 80 degree thermostat - it will be wide open at 100 degress which is stupid. I was playing around with my hondata s300 - and the middle temperature line(on the gauge) doesn't come on until the coolant temp reaches like 164 +/- 5 degrees. Atleast on my car thats when it changes.
Old Jan 26, 2006 | 06:57 PM
CivicSiDriver02's Avatar
Default Re: (TheKINGPin)
Yea I would not suggest getting it unless you are running a turbo car and your are trying to keep your temps low to keep detonation at bay. I believe that the 80 degrees mugen lists is measured in degrees C. This would be equal to 176 degress F.
Old Jan 26, 2006 | 07:00 PM
Default Re: (CivicSiDriver02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 &raquo;</TD></TR><TR><TD CLASS="quote">Yea I would not suggest getting it unless you are running a turbo car and your are trying to keep your temps low to keep detonation at bay. I believe that the 80 degrees mugen lists is measured in degrees C. This would be equal to 176 degress F.</TD></TR></TABLE>
Oh. 176 - thats cool. That would be okay. Whats the stock thermostat rating? I've never bought one.
Old Jan 26, 2006 | 07:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">
Oh. 176 - thats cool. That would be okay. Whats the stock thermostat rating? I've never bought one. </TD></TR></TABLE>
I believe it is 195. Not 100 percent sure tho.
Old Jan 26, 2006 | 07:06 PM
M2B4's Avatar
if the mugen is to low look at the spoon one it is a few degrees C higher if i remmeber correctly
90civicbns
Jul 9, 2013 04:36 PM
GSROWNSU
Dec 26, 2007 04:03 PM
fridexter
Nov 21, 2004 12:44 PM
TodaTeg
Jul 9, 2003 08:45 AM
