Swapping in a H22
Old Feb 7, 2004 | 07:22 PM
wopper's Avatar
Default Swapping in a H22
I've been searching this site and I still have a few questions: When I swap an h22 in my lude, can I still use my H23 axels? Can I still use the shifter cables and shift linkage for the H23, and is there anything else I need to know before I have this swap done? The reason I ask is because on hmotorsonline they have the 2 different options, the cheaper ($1950 i believe) just does not come with the shifter cables, linkage, and assembly so I was wondering if that was a big deal.
Old Feb 7, 2004 | 07:31 PM
Cottonwoodz's Avatar
Default Re: Swapping in a H22 (wopper)
Yes and yes...
Old Feb 7, 2004 | 07:40 PM
juicy.fn's Avatar
You can even use your H23 tranny if you want...
Old Feb 7, 2004 | 08:12 PM
Default Re: Swapping in a H22 (juicyfn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicyfn &raquo;</TD></TR><TR><TD CLASS="quote">You can even use your H23 tranny if you want...</TD></TR></TABLE>
But that would suck..
Old Feb 7, 2004 | 09:27 PM
99spanishGT
Guest
Posts: n/a
Default Re: Swapping in a H22 (Cottonwoodz)
im using my h23 tranny and it doesnt really take off till 4000rpms
Old Feb 8, 2004 | 07:36 AM
PA MATT's Avatar
Default Re: Swapping in a H22 (spanishlude)
so getting a h22 long block and then finding a tranny would be the best option? or just get the complete swap?
Old Feb 8, 2004 | 09:51 AM
TurboSam's Avatar
Default Re: Swapping in a H22 (ebpG2)
dood, always get the complete swap...dont try to piece it together like Bigjussin did, it took him 2 weeks, a lot of phone calls, and a little extra dough to get it all together...use the h22 linkage and all, and if the axles come with the swap, try them out first, unless they look like crap, then use the ones u got....
i got an H22 long block that i am going to put in my 93 Si though, i have enough spare parts lying around, and i am going to use my H23 tranny for now, but i am also gonna boost the motor, so hoefully it wont suck too bad
Old Feb 8, 2004 | 07:12 PM
PA MATT's Avatar
Default Re: Swapping in a H22 (Turbo Sam)
i was lookin at prices on osaka and its 1850 for complete swap and 1100 for long block. probably looking at couple hundred for tranny so i guess i may as well answer my own question and say it'd be better to get the complete swap
Old Feb 8, 2004 | 11:05 PM
Zimmlude's Avatar
Honestly, I would prefer an H22 that comes as a longblock. The reason being that 99% og the longblocks come from automatic tranny H22's. Since the engine was bolted to an auto tranny there is a lower chance that the previous owner raced/abused the engine before it reached you. Have you ever tried to wail on an auto before, it takes some work.
As to the swap, you can use everything except the engine itself. Don't bother swapping out the shift linkage, they are the same for the 'ludes. Same story with the axels.
Old Feb 9, 2004 | 05:13 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpG2 &raquo;</TD></TR><TR><TD CLASS="quote">i was lookin at prices on osaka and its 1850 for complete swap and 1100 for long block. probably looking at couple hundred for tranny so i guess i may as well answer my own question and say it'd be better to get the complete swap</TD></TR></TABLE>
do a search before you even think of doing buisness with osaka.
Old Feb 9, 2004 | 08:11 AM
PA MATT's Avatar
Default Re: Swapping in a H22 (CHK4TIX)
yeh..ive heard horror stories about osaka...first company that came to mind so i went there to check out prices
would the h23 tranny suck on the h22? is ecu different?
MJT805
Apr 30, 2009 11:06 AM
live2ride31
Jan 29, 2007 12:03 PM
msinsky14
Jun 17, 2006 09:08 PM
rjrmotorsport
Sep 24, 2003 09:46 AM
