Stock Flwheel ?
Old Mar 19, 2007 | 04:54 PM
LukieLuc's Avatar
Default Stock Flwheel ?
Does anyone know how much does a stock flywheel weight? the reason im asking is because i want to get a lighter flywheel but not that much lighter because i do allot of highway driving to school and will not like to loose that much on my gas milage
And also can you suggest a flywheel that will give me a difference performance wise, with out that much of my gas milage?
Old Mar 19, 2007 | 04:57 PM
4thgenner's Avatar
i think its around 21 lbs
Old Mar 19, 2007 | 05:28 PM
InvaderTrax's Avatar
20lbs
Old Mar 19, 2007 | 05:47 PM
M@'s Avatar
M@
Default Re: (InvaderTrax)
I can't really see how a fly wheel would change your gas mileage unless you are needing to rev alot more to begin from a stop.
The reason I say this is because with the clutch out your whole drive train as well as the weight of the car are apart of the momentum, and well... before I go to far I'll just wait to see whats up.
Old Mar 19, 2007 | 06:28 PM
Chris F's Avatar
Default Re: Stock Flwheel ? (lukieluc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lukieluc &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know how much does a stock flywheel weight? the reason im asking is because i want to get a lighter flywheel but not that much lighter because i do allot of highway driving to school and will not like to loose that much on my gas milage
And also can you suggest a flywheel that will give me a difference performance wise, with out that much of my gas milage?</TD></TR></TABLE>
It will NOT hurt highway mileage. It will only help city, or stop and go driving.
https://honda-tech.com/zerothread?id=1924794
Quit being a wuss and get the 8 lb flywheel.
Old Mar 19, 2007 | 08:16 PM
TDCTyler's Avatar
I use a stock flywheel, but then again I can get them from Honda for about 10 bucks.
If I were you I would get an 8lb flywheel for sure.
CTGrey06RSX-S
Jan 11, 2008 06:16 PM
Flood5
Honda Civic (2006 - 2015)
May 22, 2007 03:21 PM
ajbucci
May 20, 2006 09:39 AM
B16CivicHB
Jan 28, 2002 06:31 AM
Lo-Buck EF
Jan 7, 2002 02:16 PM
