steering wheel not centered
Old Jul 3, 2003 | 02:03 PM
kb798's Avatar
Default steering wheel not centered
i got an alignment today and when i got the car back, he told me that the steering wheel is a little bit skewed to the right when the car is bearing straight. he told me that this is because the tie rod is broken?
is he correct and how much would it be to replace?
thanks in advance.
edit: he also said that the steering wheel has a slight vibration
Modified by kb798 at 11:14 PM 7/3/2003
one more, he said it was only on the front right that was broken..
Modified by kb798 at 11:15 PM 7/3/2003
Old Jul 3, 2003 | 02:07 PM
Buckwild's Avatar
Yeah that sounds about right.
When I installed my steering wheel, it was a tooth off. The alignment shop simply adjusted the tie rods and got it back to center.
Don't know how much it is to replace a tierod tho sorry.
Old Jul 3, 2003 | 02:25 PM
Greyout's Avatar
Default Re: (Buckwild)
they can align the car to the steering wheel if you ask them to.
Old Jul 3, 2003 | 07:42 PM
atlprelude01's Avatar
so tie rods, would be the only thing wrong if the steering wheel is a lil sideways. (but everything else is lined up and driving straight)
Thats the only thing I didnt get fixed when I was involved in an accident, my car drives straight and mechanic fixed everything but steering wheel.
Old Jul 4, 2003 | 07:19 AM
r1emperor's Avatar
Don't let anyone fool you, a car can't be aligned correctly with a bad tie-rod. Also if the car is driving straight it doesn't mean it won't wear your tires. The only reason that a steering wheel CANNOT be centered is if the rack or rack bushings are bad.
215civic215
16
Mar 10, 2013 10:30 AM
lildragon'07
13
Jun 2, 2010 08:31 AM
jaycetan
17
Mar 26, 2005 11:19 AM
Ill
Jul 13, 2004 06:25 PM
