squealing noise?
Subscribe
Apr 24, 2014 | 12:16 PM
1992 prelude...replaced the alt. and power steering belts, have also adjusted them and adjusted them and cleaned the pulleys and im still getting a horrible squealing noise, it is basically consistent but gets louder and once in a while goes away for a minute....suggestions on what it could be?....
Reply 0
Apr 24, 2014 | 01:00 PM
Re: squealing noise?
timing belt?
Reply 0
Apr 24, 2014 | 02:17 PM
were you getting the squeal before you did the work? maybe the belts are too tight or loose, or if it was already happening before, maybe a bad power steering pump
Reply 0
Apr 28, 2014 | 11:39 AM
hey thanks for the ideas....it actually turns out there was a few problems (just for anyone else who may be trouble-shooting this) the bearings in my alternator were shot I had my alt. rebuilt... I took my belts off and spun the wheel on my alt. was making a squeaky rusty sound when I turned the pulley by hand. so after I fixed that it was okay for a minute...then it started again but less of a squeak. watching my belts and pulleys I noticed after a lot of reving that the harmonic balancer was moving (it was broken) so I replaced that and problem solved. also to check the power steering pump just to make sure it wasn't slacking I took the belt off and ran it (if it had been the pump it wouldn't squeak if it wasn't hooked up right?)
Reply 0
Subscribe
