spray or no?
Old Feb 14, 2004 | 07:27 PM
Shakes's Avatar
space cadet
Default spray or no?
ok, opening day at the track is the 28th. here are mods.
00 Lude SH (most important of all i think)
AEM Fuel Rail
AEM Fuel Pressure regulator (set to 40psi from AEM)
AEM CAI
Thermal Catback
Prospeed header (awaiting arrival)
Kteller test pipe
mallory ignition
VAFC (mildly tuned... leaned out a tad)
clutchmasters 12 LB flywheel
ACT XTSS
2 step colder plugs; i hope... anthony gave me the part #... so if they are wrong its all his fault
gauges
Nitrous Express Direct port kit jetted to a 100 shot (smallest jets i have )
ok, here is the thing. i had dyno time set for the 24th. but due to $$ taking priority elsewhere i will not be able to dyno before the track.
just cant decide as of yet what to do. i am leaning towards just going N/A since its the first time to the track anyhow. but i really wanna see what i can pull on the bottle.... i know, im being greedy i guess.....
Old Feb 14, 2004 | 07:37 PM
patastinky's Avatar
Default Re: spray or no? (shakes)
naWz 0wn3Z j00
Old Feb 14, 2004 | 07:39 PM
Shakes's Avatar
space cadet
Default Re: spray or no? (patastinky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes &raquo;</TD></TR><TR><TD CLASS="quote">Nitrous Express Direct port kit jetted to a 100 shot (smallest jets i have )</TD></TR></TABLE>
Old Feb 14, 2004 | 07:54 PM
Daboi630's Avatar
i voted NA just because i think its safer.
plus i want you to dyno that thing
Old Feb 14, 2004 | 07:56 PM
SUB-0 H23's Avatar
Default Re: (Daboi630)
i vote ,n20, cause it is so kool.
Old Feb 14, 2004 | 07:59 PM
preluda92's Avatar
Default Re: (SUB-0 H23)
Spraying a 100shot on a stock bottom end is nutz. I'd be nervous about 50.
Old Feb 14, 2004 | 08:04 PM
Shakes's Avatar
space cadet
Default Re: (preluda92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 &raquo;</TD></TR><TR><TD CLASS="quote">Spraying a 100shot on a stock bottom end is nutz. I'd be nervous about 50.
why? lots of guys are running 100 shots on stock h22a bottom ends....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 &raquo;</TD></TR><TR><TD CLASS="quote">plus i want you to dyno that thing </TD></TR></TABLE>
ill dyno it reguardless... just next month now most likely.
and ill have the cam gears on by then as well if i dont get them on in time for the track. not that they would make a differance being at 0-0 but the new t-belt would be nice to have on there.
Modified by shakes at 12:42 AM 2/15/2004
Old Feb 14, 2004 | 09:00 PM
PapaPark's Avatar
HT White Ops
Default Re: (shakes)
I'd definitely run n/a first
Old Feb 14, 2004 | 09:04 PM
Shakes's Avatar
space cadet
Default Re: (PapaPark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PapaPark &raquo;</TD></TR><TR><TD CLASS="quote">I'd definitely run n/a first</TD></TR></TABLE>
of course you would say that. you dont want to tow me back to va beach .
oh, and im special... i can **** that up too
Old Feb 14, 2004 | 10:00 PM
PapaPark's Avatar
HT White Ops
of course you would say that. you dont want to tow me back to va beach .</TD></TR></TABLE>
Old Feb 15, 2004 | 12:55 AM
SKDRCR's Avatar
i would go n/a since it's your first run of the season.
think of it as baseline runs,
then you can compare them and see how much the
direct port system benefit's you.
are you gonna be retarding the ignition at all?
Old Feb 15, 2004 | 04:43 AM
Shakes's Avatar
space cadet
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">i would go n/a since it's your first run of the season.
are you gonna be retarding the ignition at all?</TD></TR></TABLE>
of course.
nothing on my car has been half assed as of yet. thats why i am really leaning towards N/A.
i want to put a new fuel pump in and tune it with everything.
Old Feb 15, 2004 | 06:16 AM
mike1627's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes &raquo;</TD></TR><TR><TD CLASS="quote">of course.
i want to put a new fuel pump in and tune it with everything.</TD></TR></TABLE>
I just found out I've been leaning out the motor with a 55 shot, so i think a fuel pump would be a good idea with a 100 shot. Also keep in mind that Nitrous Express rates their shots to the wheels, so that 100 shot is more like 125 shot.
Old Feb 15, 2004 | 07:11 AM
Jagan'92's Avatar
N/A first!
i better hit post, cause i'm about to say go ahead and spr
Old Feb 15, 2004 | 07:31 AM
'99luder's Avatar
damn.. dont mean to ***** but your setup is oh so close to my proposed spring setup. Cant wait to see dyno numbers..
Old Feb 15, 2004 | 07:54 AM
MugenPoweredLude's Avatar
id run N/A first
all the while saving up for a Hondata
Old Feb 15, 2004 | 09:06 AM
Shakes's Avatar
space cadet
Default Re: (MugenPoweredLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenPoweredLude &raquo;</TD></TR><TR><TD CLASS="quote">
all the while saving up for a Hondata </TD></TR></TABLE>
oh yeah, thats gunna happen lol
Old Feb 15, 2004 | 10:40 AM
LudeyKrus's Avatar
I voted n/a so you have a baseline run
Old Feb 15, 2004 | 03:56 PM
Kendall's Avatar
I think you've already decided. You just want someone else to say it so that the blame won't be on you if you blow it up.
Old Feb 15, 2004 | 03:58 PM
Shakes's Avatar
space cadet
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I think you've already decided. You just want someone else to say it so that the blame won't be on you if you blow it up.</TD></TR></TABLE>
lol,
i think ill go NA for the first time to the track. then ill hit up the 1/8th mile for seat time and to get used to spraying on the track.
Old Feb 15, 2004 | 07:48 PM
NXLude's Avatar
Go NA, you would be foolish to run 100 shot on you r motor. First you will not go that uch faster, without slicks you wont get traction. A 100 shot of NX will make close to 125 whp, that is too much for stock internals! In addition to that your fuel pump will have a hrd time providing for 300whp, (which is what you will be making). I suggest you spend the 5 dollars on some new jets and run a 75 shot or have some custom 65 shot jets made up. Most guys I have talked to gained 90-95 whp from a 75 shot. That is as far as I would push my stock motor.
Old Feb 15, 2004 | 10:08 PM
7808's Avatar
Default Re: (NXLude)
have you spayed your engine w/100 shot yet? i'd be ****** nervous...
Old Feb 15, 2004 | 10:10 PM
Shakes's Avatar
space cadet
Default Re: (fuctup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">have you spayed your engine w/100 shot yet? i'd be ****** nervous...</TD></TR></TABLE>
nope not yet. if i had i wouldnt have posted this. i would have just sprayed at the track
Old Feb 15, 2004 | 10:33 PM
Matgallis's Avatar
BOOM
Old Feb 16, 2004 | 04:49 PM
93ludeSi's Avatar
Default Re: (Matgallis)
seems like a lot of risk just too see how fast you can go, i would wait and out and play it safe.
