Speedometer not working
Old Feb 2, 2009 | 07:26 PM
NineT1Lude's Avatar
Banned
Default Speedometer not working
is it the speed sensor?
once in a while it'd go up and down and sometimes it would work but for the most part it doesnt.
and the needles dont light up either...
Old Feb 2, 2009 | 07:31 PM
Kronn 98SH's Avatar
Default Re: Speedometer not working
The VSS is the main sensor that controls the speedo. If your needles don't turn on, that suggests something else though. The needles should be controlled by the same lights and switch as the rest of your dash lights. Do those work?
Old Feb 2, 2009 | 07:34 PM
NineT1Lude's Avatar
Banned
so for the speedometer not working ur saying i need to replace the speed sensor right? the RPMs work, just not the speed one.
and yeah the other dash lights all work, it's only the needles that dont..
Old Feb 2, 2009 | 07:36 PM
Kronn 98SH's Avatar
That sounds less like a sensor and more like an electrical problem, like an open circuit to your speedo. IIRC, when the VSS goes bad, the tach stops working as well.
Old Feb 2, 2009 | 07:42 PM
NineT1Lude's Avatar
Banned
what's IIRC?
i asked the guy that sold me the car what the problem was and he said the speed sensor needed to be replaced. so i dont know....
Old Feb 2, 2009 | 07:57 PM
Kronn 98SH's Avatar
IIRC = If I Recall Correctly.
Old Feb 2, 2009 | 08:40 PM
NineT1Lude's Avatar
Banned
so if its an open circuit how do i fix that
Old Feb 2, 2009 | 09:26 PM
Kronn 98SH's Avatar
An open circuit could be caused by something like a cut wire or a faulty component preventing the electricity from flowing. The cure for an open circuit is to close the circuit.
Old Feb 3, 2009 | 05:15 AM
NineT1Lude's Avatar
Banned
obviously.
so it just needs to be replaced or checked out or what...
Old Feb 6, 2009 | 11:18 PM
Bad_dude's Avatar
Not true, when my VSS went out, my tach still works. I have a 1990 Honda Accord LX.
The problem I have now is a sticky Speedo. When it's cold in the morning, the speedo does not go up some times but once it's up then it's up all day.
Do you guys think it's the electronic component behind the speedo, or does it needs a lubing or cleaning?
Thanks.
Old Feb 6, 2009 | 11:43 PM
GraphiteMW's Avatar
Thanks.
Sounds like the connection on top the VSS
Old Feb 7, 2009 | 05:25 AM
teambk8's Avatar
i had the same problems with my 4th gen when I bought it, tach worked but no spedo... replaced the sensor on the tranny with one for autozone and now, 2 years later, still works! Pretty easy install, replace the sensor first THEN if that doesn't work look elsewhere, but start with the path of least resistance. IMO
blaze.1
Sep 10, 2009 06:24 AM
ixoiiiiviviiivi
Jul 15, 2008 09:21 PM
turismo128
Sep 27, 2005 03:22 PM
chris78
Jun 6, 2005 06:01 PM
