Speed meter problem..
Old Feb 10, 2005 | 11:27 AM
951dc5's Avatar
Default Speed meter problem..
93ludevtec; havin problems with the speed meter that won't funtion after a while then engine is completely hot. thanks
Old Feb 10, 2005 | 11:55 AM
Sephro's Avatar
Default Re: Speed meter problem.. (Prelude951)
Check your Speed sensor...
Old Feb 10, 2005 | 12:03 PM
951dc5's Avatar
Default Re: Speed meter problem.. (Sephro)
where is that speed sensor located>
Old Feb 10, 2005 | 05:21 PM
PrettyLude's Avatar
speed sensor is where you throttle body is and look straight down
Old Feb 10, 2005 | 11:36 PM
tdo's Avatar
tdo
Default Re: (PrettyLude)
i have kind of the same problem.
Sometimes the stick on the MPH gauge flickers and sometimes it even dies, then after a while it will come back to normal. One time it didnt work for a couple days.
is this the speed sensor as well?
Old Feb 11, 2005 | 06:52 AM
PrettyLude's Avatar
check and see if you have any moisture inside the connector that goes to the speed sensor
Old Feb 13, 2005 | 10:06 AM
951dc5's Avatar
that might be it..i'ma go check.
Old Feb 13, 2005 | 10:48 AM
mgags7's Avatar
for the one with the flickering guages, thats an electric problem with the guages.....if you can see the needle, and its still at the right speed, then your VSS (vehicle speed sensor) is fine.....
for you whose wont work when the engine is hot......make sure the wires arent corroded, and check for wetness like ^^ said......
if neither work, you may need a new VSS.....
blaze.1
Sep 10, 2009 06:24 AM
doubleoazn03
Sep 5, 2008 10:33 PM
aziaticvang
Jan 13, 2008 06:35 PM
1Ek 1Eg
Jan 13, 2006 02:14 PM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
