Smashed thrust washer H22
Old May 12, 2009 | 03:24 AM
qpe's Avatar
qpe
Default Smashed thrust washer H22
I'm just going to rebuild my engine and noticed that one of thrust washers is in not rally in good condition (flywheel side one) , the other is actually untouched
the question is shall i get smaller one for the right side and bigger for the other so i could avoid happening this again
Old May 12, 2009 | 03:59 AM
PirateMcFred's Avatar
Default Re: Smashed thrust washer H22
The FW side thrust washer is the one that takes all the pressure from the clutch. If you use sub-par oil or a heavy clutch pressure plate spring or you ride the clutch while at traffic lights then that will cause that thrust washer to wear faster. In your pics there it looks like the crank's thrust washer surface needs to be machined as it's no longer flat and smooth.
I don't think that there are different sizes of thrust washers from Honda. It's just one size. I've known people to swap the two from side to side to even out the wear on budget rebuilds but for the price it's just easier to replace them both. After you do that you just need to check the crank end play along its axis of rotation. If it's too sloppy with new bearings then you'll need to fix/replace the crank.
Cheers,
Pirate
Old May 12, 2009 | 05:53 AM
qpe's Avatar
qpe
Pirate
i thought so , i took pictures but u cant really see much on them , i'm sure i have to sort it out ,it doesn't feel good when you checking it with your finger
Cheers,
Pirate
i didn't actually check if there are diff sizes ,
i wouldn't use the old ones anyway , there are not too expensive to take a risk
Thanks for fast reply Pirate
Old May 13, 2009 | 08:32 AM
flyrod's Avatar
You could also remove the clutch switch cutout on the starter circuit so that you can start the car without holding in the clutch. Make sure it's not in gear though... That saves wear on the thrust bearing on startup when it doesn't have any oil.
Old May 13, 2009 | 10:32 AM
hondaZvic's Avatar
this is done on my hatch.
i must admit i like it, however its not safe. im used to it, but from time to time people will move my car or whatever and they tend to like to park in gear for some strange reason no matter how many times i tell them its not necessary and DONT do it... lol... there have been times when i have started it and its been in gear... im lucky nothing has happened though..
2000Accord5sp
Northwest (Sales)
Apr 6, 2006 07:34 PM
2000Accord5sp
Feb 27, 2006 04:40 PM
2000Accord5sp
Feb 26, 2006 09:31 AM
Maddox
May 16, 2004 05:00 PM
