skunk2 valve?
Old Feb 12, 2004 | 03:12 PM
mikesterny's Avatar
Default skunk2 valve?
will a skunk2 standard valve just drop in my stock engine?
Old Feb 12, 2004 | 03:19 PM
Cottonwoodz's Avatar
Default Re: skunk2 valve? (mikesterny)
It wont just drop in, I mean your going to have to take the head off atleast..
Old Feb 12, 2004 | 06:41 PM
speedracer9k's Avatar
once you pull the head off, you'll need to get the valve springs and retainers off (valve sping compressor helps alot) then the old valves slide right out and you can just slide the new one in, then you get to the hard part putting the keepers back into the retainer to hold the retainers on the springs which keeps the valves in. I just rebuild my head last weekend and that was the hardest part of the job.
Old Feb 12, 2004 | 07:30 PM
tuan...'s Avatar
woudlnt u have to regrind the seats for a new valve?? that is what my machining shop told me they had to do to put my new set of valves in..
Old Feb 12, 2004 | 08:01 PM
SilverEk3dr's Avatar
Default Re: (h22a4_dc2)
If the valve seats are ok. Then you can get away with lapping the new valves in, and go. Thats what I did to mine, but it was relatively low mileage at the time.
Old Feb 13, 2004 | 08:30 AM
you dont need to regrind the vlve seats, the new valves just slide right in as long as the valve seats are in good condition
Old Feb 13, 2004 | 08:56 AM
JDM BB2's Avatar
It's recommended to use bronze valve guides as the stainless steel valves have a tendency to wear out the factory valve guides. Bronze guides are very inexpensive and well worth it if your spending all that money to bullet proof your valvetrain.
-Mike
Old Feb 13, 2004 | 01:09 PM
blueludejdm's Avatar
Default Re: (JDM BB2)
ok i bent a valve and i want to just build my h22a NA and i was just was going to buy skunk2 valves but the have three sizes stock .5 1. what does that mean y would i want bigger valves? and if i put bigger valve in what would i have to do to the head to put bigger valves in?
Old Feb 13, 2004 | 04:04 PM
aeolus's Avatar
Default Re: (blueludejdm)
unless you are going bigger bore or forced induction,then you don't need bigger valves...they can also liimit the size cams you wanna use.i have never heard of a valve just dropping in,and if you try to do so,i garantee you will burn a valve.if the seats are not in bad shape,they you can get away with just lapping the new valves in.But,since the head will have to be all apart,might as well have the seats freshened up.And if the machine shop you go to is rally good,you may not even have to lap the new valves in.If you have no idea on how to make sure your valves are seating right,let someone who knows does do it for u.
fatpride111
29
Nov 14, 2008 09:01 AM
SupraManAG
Feb 15, 2008 08:48 PM
LSTEG96
Sep 8, 2007 05:08 PM
7rrivera7
Nov 7, 2005 03:42 PM
boomslang
Sep 17, 2002 07:23 AM
