Running rich............
Old Aug 15, 2004 | 07:12 PM
RemerLex11's Avatar
Default Running rich............
I have a 99 h22 with header, exhaust, intake, and a mugen ecu and im running rich. I recently got an air/fuel gauge and it reads rich to the end of the gauge. Also, I can smell the gas instead of the exhuast and i have a bouncy idle. What can i do to try and fix this without replacing the O2 sensor unless that's my only option.
Old Aug 16, 2004 | 08:35 AM
tomtom211's Avatar
Default Re: Running rich............ (mafoo_2005)
you can try leaning it out a bit with a Fuel pressure regulator or get do it the right way with hondata or VAFC with some wideband tuning.
Old Aug 16, 2004 | 08:41 AM
Revi's Avatar
Default Re: Running rich............ (tomtom211)
Well if your o2 sensor is bad or going bad, you can adjust the fuel anyway you want and its still gonna be screwed up. So first make sure the o2 sensor is fine, then lean it out via VAFC or anyother fuel management computer.
Old Aug 16, 2004 | 09:50 AM
SKDRCR's Avatar
Default Re: Running rich............ (Revi-Ra)
do you have a stock ecu to check it with
and see if that's the problem?
Old Aug 16, 2004 | 09:58 AM
vtecpreludude's Avatar
hey, well i have a 96 w/ a obdI h22a & ecu and have the EXACT same problem w/ our friend who is posting this. So i could have a bad O2 sensor as well?
OrangeTeggy
Jun 16, 2009 09:52 PM
AllMotorDA9
Oct 26, 2004 06:27 AM
NuclearB18B
Nov 7, 2003 09:33 PM
jdmtim
Jan 26, 2003 10:58 AM
5gen-hybrid
Aug 13, 2001 09:51 PM
