Rotrex h22a
Old Jun 21, 2009 | 07:32 AM
BrizzlEK's Avatar
Default Rotrex h22a
i have decided im going to boost my obd1 h22a. I wish to go with a supercharger and i know the JRSC wont fit, i havent found any kits for my model and was hoping someone knew what was needed to run rotrex? From looking at kits for other cars it looks like tb to supercharger, and supercharger to belt but there is more in the kits than that. What else do i need?
Thanks
Brent
Old Jun 21, 2009 | 07:42 AM
street_ride14's Avatar
Default Re: Rotrex h22a
" The Rotex is designed to spin one way, clockwise, the H22a spins counter clockwise so in order for a Rotex SC to actually work you would have to put it on the H22a facing backwards, or away from the belts. This would make mounting and belt routing a nightmare. "
-- http://www.preludeonline.com/f69/thi...harger-226875/
Go F/I with a turbo.
Old Jun 21, 2009 | 01:58 PM
InvaderTrax's Avatar
Do it like a tC with a long shaft running across the engine
Old Jun 21, 2009 | 04:55 PM
Enzo15's Avatar
The only reason the Tc has the shaft is because there is no room by the belts, and the h22 spins counter-clockwise, so a shaft wont really do anything.
Old Jun 21, 2009 | 05:09 PM
prion's Avatar
A shaft with some sprockets on the end! That'll do.
Old Jun 21, 2009 | 06:57 PM
If the shaft is spun counter clockwise by the motor, the rotex on the other side would be spun clockwise, assuming it's mean to be spun clockwise with the pulley on the left side
Old Jun 22, 2009 | 07:57 AM
NirVTEC's Avatar
Look into Turbos.....Just don't bother boosting a stock motor. If you're looking for quick power/torque........Start reading about how wonderful Nitrous is.
Old Jun 22, 2009 | 08:44 AM
BrizzlEK's Avatar
i wanted to do something different, whatever f/i i do it'll be after some internal work on the motor. im looking for some gain in power and torque but not a lot what turbo will spool quickly on the h without overdoing it? im posting before researching right now but i only wanna do 7-10 pounds of boost
Old Jun 22, 2009 | 10:18 AM
NirVTEC's Avatar
We used a Precision GT30R on my friends Prelude with a Rev Hard manifold......
287whp@10psi
7-10psi *YAWN*
Old Jun 22, 2009 | 10:37 PM
BrizzlEK's Avatar
ha ha sorry, i have ridden in some high boost hondas and its nice but not for me, i just want a wee bump in power so it wont get too notice-able
Old Jun 22, 2009 | 10:43 PM
dagle's Avatar
get the JRSC then, it can be modified to fit last I recall.
or go with a ball bearing turbo setup. i'd suggest the GT28 since your power goals are low. the only thing about a responsive early-spooling turbo setup is that it will blow-off very often. if you don't want to draw attention to your car when you're driving i'd suggest looking into routing the BOV upstream now.
Old Jun 25, 2009 | 04:26 PM
gooselude's Avatar
turbonetics makes a full t3/t4 setup for the 92-96 prelude h22a1 ob1. even comes with a preset air fuel maps. still would want to either rebuild the internals or upgrade. but its a quick spooling setup and would give you a moderate power bump your looking for and as far as the lots of blow off valve sounds and drawing attention quick solution: get a recirc. valve instead. omg problem solved.
hope this helps.
Old Jun 25, 2009 | 04:50 PM
dagle's Avatar
i said route the BOV upstream genius
and look at his power goals, there's no need to build the motor until it blows. it can be plenty reliable for the mild power gains hes looking for
Old Jun 25, 2009 | 05:00 PM
gooselude's Avatar
ya know i thought about gettin back with some harsh words but i'm not stoopin to a new low. and never once did i say you were stupid, dumb or idiotic in any way. so yes i recognize you said reroute upstream, but some people wont understand what you're talking about. so if you thought i was bashing your response you have misunderstood me. and i said rebuild or upgrade (the upgrade would be later if he felt he wants a lil more power). rebuilding would just make it more reliable. some people dont want to "boost til it blows" because they dont want to have to replace or pull the motor more than they have to.
and for anyone wanting to come back at me for the things i say, just know i'm only on this forum to help people with a passion for hondas. so trying to argue with me will end up a one sided conversation.
happy boosting.
jay525
Mar 3, 2019 08:10 PM
03K24A4EX
Apr 18, 2006 08:56 AM
Accord6Gen
Jun 30, 2004 04:49 AM
H22A EG6
Mar 3, 2004 02:53 PM
