redline
Old Feb 5, 2010 | 06:58 PM
BoiTypeR's Avatar
Default redline
Wondering if they're people that have preludes that redline around 10k. Is it safe to go 10k rpm? real talk im being serious.
Old Feb 5, 2010 | 07:18 PM
88h22_CRX's Avatar
Default Re: redline
If you have stock internals and valvetrain... 8500 is the highest you ever want to go. Anything higher than that and you are looking for problems.
Old Feb 5, 2010 | 07:44 PM
letsdrive's Avatar
Default Re: redline
only cars with upgraded valvesprings and valvetrain should be reving that high. plus you need a reason to be reving to 10,000, i.e. cams with a powerband that high.
Old Feb 5, 2010 | 11:25 PM
slomofo's Avatar
GDD Member
Default Re: redline
I did 10k daily in a stock Civic with CRX Si engine... it last about a week before valve float occured and the engine took a dump. I was hoping to blow it in a day, but was surprised it lasted the full week. Your valve keepers will fall off on a stock valvetrain if you rev that high, so don't do it unless you're blowing it on purpose.
Old Feb 6, 2010 | 12:20 AM
drae09's Avatar
Default Re: redline
upgrade your valvetrain first !
Old Feb 6, 2010 | 01:09 AM
HdeucedeuceA's Avatar
Default Re: redline
So you upgrade you valveterain and throw in a set of cams for that RPM band. Then what? Do you guys seriously think an OEM H22 block can handle 10k rpm's?
Old Feb 6, 2010 | 07:37 AM
KreLude's Avatar
Default Re: redline
Thats even pushing it. There's just no reason to rev that high. You stopped making power almost 1500rpm before.
Even if you built a motor that could handle 10k rpm, good luck shifting gears at 10k with an H series trans.
Truth be told, this is really a Ricey Question considering the amount of info in the FAQs.
Old Feb 6, 2010 | 08:39 AM
Enzo15's Avatar
Default Re: redline
Im curious, why couldnt you shift at 10k with an H series trans?
Old Feb 6, 2010 | 09:15 AM
KreLude's Avatar
Default Re: redline
GL shifting any cable controlled trans that high.
This is why the B/D series guys love their rods shifted trans.
Blk93Sihatch
Feb 2, 2006 01:12 PM
hondaACCORD
Jul 4, 2004 09:19 AM
vbspec
26
Mar 25, 2004 07:42 PM
E46M3CB
Feb 28, 2002 11:09 AM
austrian type-R
Oct 10, 2001 05:40 PM
