puel pump?
Old Dec 12, 2009 | 03:46 PM
313hitman's Avatar
Default puel pump?
hey all. I was driving at 55 mph when my car started surging and exhaust backfired a couple times just like a car running out of fuel. the tach wasnt jumping so I figured it wasnt crossed wires. It hasnt shut off on me yet but it does it after driving several miles. before winter I changed fuel filter plugs, cap,rotor, and coil(it went bad) so Im assuming f/p if anyone thinks different or have any other suggestion please help. motor is jdm h22a 66k miles and body has 220k
Old Dec 12, 2009 | 05:41 PM
Matt55's Avatar
Default Re: puel pump?
so it idles fine?
Old Dec 12, 2009 | 05:46 PM
313hitman's Avatar
idles perfect. its 20 degrees here so it idles high at 1500rpm durring start-up then of course comes back down to normal
Old Dec 12, 2009 | 05:50 PM
Matt55's Avatar
does it start actin up at a certain rpm?
Old Dec 12, 2009 | 06:02 PM
313hitman's Avatar
It just started today but it seems to do it in any gear any rpm. but when I pulled over and sat there in idle for a minute or 2 i drove it home(4 miles) with no issues I just want to know should I be preparing to get a f/p soon or could it be distributor
Old Dec 12, 2009 | 06:04 PM
Matt55's Avatar
if it was the fuel pump it wld affect your car all the time not randomly, and the dizzy wld cause missfires, i wld start checking sensors
Old Dec 12, 2009 | 06:06 PM
313hitman's Avatar
like what. this is very sudden.
Old Dec 12, 2009 | 06:13 PM
Matt55's Avatar
what is sudden? umm check your maf, and check your timing, fuel filter, o2 sensor, and you can check your dizzy to see if its adjusted correctly, oh and vacuum leaks
Old Dec 12, 2009 | 06:22 PM
313hitman's Avatar
never happened ever. I was 10 miles into my trip when it started doing it. also where is the maf. I have a sensor on top of my throttle body that is unplugged with no wires next to it.
Old Dec 12, 2009 | 06:34 PM
Matt55's Avatar
did you just take that pic now lol? that is your tps sensor, you shld probably plug that back in lol
Old Dec 12, 2009 | 06:44 PM
313hitman's Avatar
it has never been plugged up since I bought it. plus its a swap so it has no wires running to it on the harness. I thought tps is the sensor on the opposite side of the throttle lever and is controlled by the throtte shaft??
Old Dec 12, 2009 | 06:56 PM
Matt55's Avatar
oh well if it was never plugged in its irrelevant then
Old Dec 12, 2009 | 11:43 PM
TheJGB3's Avatar
MAP sensor (manifold absolute pressure)
Old Dec 13, 2009 | 07:03 AM
313hitman's Avatar
anyone know how to wire the map.
Old Dec 13, 2009 | 07:49 AM
Enzo15's Avatar
I want to say that there are a couple of vaccumm ports just right of the sensor that are connected as part of the throttle body, might be unplugged as well, which Im pretty sure would cause vaccumm leaks.... Idk just a thought...
Old Dec 13, 2009 | 05:56 PM
313hitman's Avatar
im going to connect my fuel guage and look at as i drive so if pressure drops its the f/p let you guys know tomarrow
Jeremy Dunn
Aug 18, 2017 10:34 AM
rivoe302er
Mar 29, 2010 06:12 PM
GSRinGER
Sep 17, 2008 06:29 AM
the.hamburglar
Sep 10, 2007 05:10 PM
CivicSoul
Feb 21, 2002 11:46 PM
