Problem with VTEC
Old Mar 16, 2003 | 08:10 AM
SpeedGyrl's Avatar
Default Problem with VTEC
Has anyone else ever had problems with VTEC kicking in on a 5th gen Prelude? I had no problem with it until Friday, and then all of a sudden VTEC wouldn't kick in at all. Thanks.
Old Mar 16, 2003 | 08:14 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Problem with VTEC (99LudeGyrl)
check your oil level. make sure the car is warmed up before you hit vtec. i hope it's not your solenoid.
Old Mar 16, 2003 | 08:17 AM
SpeedGyrl's Avatar
Default Re: Problem with VTEC (Sticky Tires)
Oil is fine... It was like 75 outside and car had been running for a little while... Still no VTEC.
Old Mar 16, 2003 | 08:22 AM
* B A N N E D *
are you taking it up to 5200k? sometimes the vtec sounds really low but it's there. you don't feel the pull? if it still ain't there you got a problem.
Old Mar 16, 2003 | 08:26 AM
SpeedGyrl's Avatar
I'll take it there and past and still nothing. It's like it didn't exist anymore. It kicked in some yesterday. But, there were times when it wouldn't, just like Friday.
Old Mar 16, 2003 | 08:37 AM
* B A N N E D *
sounds like your vtec solenoid is dead.
Old Mar 16, 2003 | 08:39 AM
illusion's Avatar
what is your rev limiter now?
Old Mar 16, 2003 | 09:19 AM
Boostless97Lude
Guest
Posts: n/a
whoa....... that's very unlikely... what about your connections on your solenoid? could they be loose? what about the possibility of a short in the signal wire??
do you have a CEL? if VTEC isn't engaging due to some problem with the solenoid or a connection you should be getting a CEL for VTEC failure.
what about oil?? what weight oil do you use? if it is too heavy it is possible that the little screen that goes to the VTEC pressure switch is clogged and not allowing it to read enough pressure for the solenoid to activate
Old Mar 16, 2003 | 03:56 PM
SpeedGyrl's Avatar
Default Re: Problem with VTEC (illusion)
7800 rpms
Old Mar 16, 2003 | 04:12 PM
Elkins911's Avatar
if your vtec isnt ingaging, you should have a lower rev limit than usual. i think...
i know thats how it is when you put a vtec computer on a nonvtec car. your car will redline when your comp signals vtec. makes sense that it would work oppisite ways.
i guess all you can do is a few voltage tests on your car to see if vtec is engaging... maybe your just paranoid?????
[Modified by Elkins911, 1:13 AM 3/17/2003]
Old Mar 16, 2003 | 04:14 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Problem with VTEC (Elkins911)
not necesarily
Old Mar 16, 2003 | 04:23 PM
Elkins911's Avatar
Default Re: Problem with VTEC (EX-Boosted97Lude)
not necesarily
hehehe, i thought i was pissing in the wind with that one... i was taking a blind swing.... thanks for correction.
HondacivDX
Feb 19, 2012 06:52 PM
d16z6ef
11
Aug 3, 2007 06:36 AM
Fastwhip
Aug 2, 2007 03:58 PM
mister_ej1
May 23, 2007 09:40 PM
BlckSI
Aug 29, 2003 06:48 PM
