problem with ebay headlights
i work at a pizza place been driiving all night and the lights worked fine. got home and started adjusting them to the right height and angle and when i was working on the passenger side all of the sudden the passenger headlight cut out. now they do this weird thing
with lo beams on:
-high and low of passenger side are barely on
-low on drivers is on all the way and high on drivers side is barely on
with high beams on:
-high and low on pass. side are both off
-high and low on drivers side are at full power
can't figure out the problem where to start.
with lo beams on:
with high beams on:
found the problem. the inside of the lights were grounded. the high beam ground connected with the lo beam ground inside the light, spliced into one ground that goes outside the headlight with the two power wires, the ground then turns into two grounds again and is wired to each lo/high beam connector
cut the ground connection of each high beam(inside the headlight) ans also where the ground going to the connector(outside the headlight). makes the ground a single ground that just connects to lo beam. then just rewire the cut piece from the inside high beam ground to the each high beam ground connector and you are done.
also i noticed that after the wiring only the right(passenger) headlight didnt work. blown fuse. replaced and everything works again
bigballer8526
May 9, 2017 05:59 PM
spikekautz
Honda Civic (2001 - 2005)
Jan 14, 2015 09:28 PM
