Prelude spoiler
Old Apr 6, 2003 | 11:46 PM
quantguy's Avatar
Default Prelude spoiler
Alright tech folks... i heard from a friend that adding a spoiler that is not 'calibrated' for the car will actually deteriorate the performance of the car in exchange for the added look..
the physics is something like this: the rise of the spoiler on the trunk will cause additional air to be dragged under the front engine bay, causing the engine to compensate by working harder and therefore reducing MPG as well as relative performance versus the the air flow in the standard design...
any comments or proof to dispel the above myth? do post!
Old Apr 7, 2003 | 04:10 AM
visual's Avatar
Default Re: Prelude spoiler (quantguy78)
truly, there isn't much of a difference. And if there is then it isn't noticeable. I don't even think the spoiler on the prelude is functional.
Old Apr 7, 2003 | 09:24 AM
One Slow Lude's Avatar
at high speed they are supposed to "push" the back end of the car down for stability, which in turn probably does cause the front end to raise up alittle. I think it is more for looks on our everyday cars, and i "think" it better helps rear wheel drive cars who need the *** end firmly on the ground to make sure that all the availible power is being put down and to keep spin out causing lift from the back around high speed turns and such....
i could be wrong and if so please make fun of me ... i love it when they do that
Old Apr 7, 2003 | 09:46 AM
munscher's Avatar
Default Re: Prelude spoiler (POSlude97)
thats all pretty much right like you said it... wings keep the car, namely the rear end planted at high speeds (ie, not 60-80mph!) at low speeds they have next to no effect dynamicly.... changing from the stock spoiler in theory changes the dynamics of the vehicle, but the changes are so negligible that it doesnt matter unless you're racing at high rates of speed or cornering at high speeds.
Old Apr 7, 2003 | 10:18 AM
743's Avatar
743
Default Re: Prelude spoiler (munscher)
unless you own a rear wheel drive prelude or feel like bolting the wing to your hood theres really no point in getting one. I have an oem one and the only reason its still on my car is because i think the car looks retarted without one and my prelude is my daily driver. But when it comes down to it get what you want, dont let anyone make your mind up for you. Good luck.
silverlude80
Jan 6, 2011 06:13 PM
Fobstylez
Aug 6, 2005 02:58 AM
Supra
Dec 31, 2003 02:15 PM
Steve04SVT
Oct 13, 2003 11:36 AM
