Prelude shift points changed suddenly?
Old Dec 20, 2008 | 09:39 AM
hatchin's Avatar
Icon2 Prelude shift points changed suddenly?
I have a 1993 Accord with a obd1 jdm h22 with the matching auto trans and jdm tcu (transmission control unit). I needed to pull off the positive wire on the battery to work on it and when I put it back on the car now shifts at 6,000 instead of 7,200. It has shifted at 7,200 ever since the swap was done and all of the sudden it changed to 6k after I took the power wire off for about 15 minutes. Has anyone else run into this issue before? Any help would be appreciated.
Old Dec 20, 2008 | 02:56 PM
RaysBoomBoomLude's Avatar
It sounds like the TCU is re-learning
I would give it a few days.
Old Dec 20, 2008 | 03:00 PM
ethereal2pt2's Avatar
that's what happens when you pull the power. like aforementioned, it'll relearn your driving habits soon.
Old Dec 20, 2008 | 04:30 PM
hatchin's Avatar
I have manually shifted it from first to second a few times at 7k and it still shifts at 6k if I let it shift for me. I drove around slow letting it shift at like 2,500 before but when I was at wide open throttle it allways shifted at 7,200. I don't think it "learns" other wise it wouldn't have allways shifted at 7,200 at wide open throttle no matter how I previosly drove it.
Old Dec 20, 2008 | 10:20 PM
Kronn 98SH's Avatar
swap to a manual transmission and shift whenever the hell you want.
Old Dec 20, 2008 | 10:36 PM
G2IntegraGS's Avatar
word
Old Dec 20, 2008 | 11:14 PM
SOHC_4dr's Avatar
the auto tranny will shift depending on lots of variables. at wot it'll tend to shift a bit before redline because of the tq curve of the engine. give it time to relearn or manual swap ftw
Old Dec 21, 2008 | 06:23 PM
92civlude's Avatar
Default Re: Prelude shift points changed suddenly?
Doed the JDM tranny have a throttle cable attached between the throttle body and the throttle valve B lever on the tranny? It sounds like it might be too loose. The adjustment point is on the tranny.
Old Dec 22, 2008 | 03:47 PM
hatchin's Avatar
The cable is a good idea but I checked it today and it doesn't have any slack in the cable and the two locking nuts are still tight. I am guessing that my tcu has tacken a crap.
Old Dec 22, 2008 | 03:55 PM
flight50's Avatar
it actually sounds like your shifting correctly now. my car never went past 6500 before it shifted but i was using the f22 tcu as well. you reset the computer in which probably wasn't in the right mind state to begin with. the auto shifts before redline to save on the wear and tear that a 5 spd can handle unlike its counterpart. if your tcu scrapped on you, it would probably be worse than what it is.
Old Dec 22, 2008 | 04:52 PM
lude_lover's Avatar
Well if you have the true TCU(p19) which is rare but possible, it had a feature known as the "s" mode where the shift points change to make it more sportier and such. Its possible a switch needs to be hooked up to the TCU. Look into that if your stumped
Old Dec 22, 2008 | 05:15 PM
hatchin's Avatar
It is a P19 and it did shift at 7,200 at wot on any gear and now it is at 6 in every gear so that sounds like something needs to be switched. I wonder how to "switch" it back? And for Flight50 the stock F22 tcu will make it shift at redline of the F22. If you switch the tcu to a p19 it will shift at 7,200 all day like mine used to (as long as your ecu is a P13 and has the auto matic wire connected to the proper terminal on the harness).
Old Dec 22, 2008 | 07:25 PM
lude_lover's Avatar
IMO i wouldnt be shifting that high because honda automatics are really really really poorly build. Ive only had my H22/auto for 10k miles and its already slipping really bad. 5 speed swap will smooth things up : )
But just so you can check, the pin D20 on the TCU is the S switch wire. Just FYI USDM preludes were not wired for the "s" switch so you can go buy a normal on/off switch at an autopart store to wire it in. If there is a wire on you D20, it should be red according to the JDM service manual
Old Dec 22, 2008 | 08:27 PM
hatchin's Avatar
When I wire the switch what is the red wire? Is it a power wire (so the other wire on the switch needs to be a ground)?
Old Dec 23, 2008 | 09:27 AM
flight50's Avatar
its your car. your pushing your luck going that high with an automatic. unless your just trying to break it so you can do a 5 spd swap, i'd deal with the quicker shift points. and no, my car never dipped into the red valve when i pushed here using the f22 tcu. maybe my installer hooked it up right or they hooked it up wrong, but either way, until i swapped over to a 5 speed, my tranny held together. and i pushed it every chance i got. including chirping my tires for a second in first gear.
Old Dec 23, 2008 | 01:36 PM
lude_lover's Avatar
Correct.
Old Dec 24, 2008 | 08:36 AM
hatchin's Avatar
I appreciate everyones help on this and I will wire up a switch this weekend and try it out.
Old Dec 29, 2009 | 01:11 PM
swear4none's Avatar
New User
bro,
does your rewiring work for your p19tcu? I also have a p19tcu/p13ecu but the car only shift at 6500.
RyanA
Transmission & Drivetrain
Sep 12, 2009 05:26 AM
jjspec
Oct 31, 2008 03:10 AM
slow99accord
May 14, 2003 09:54 PM
MyWhiteCivic
Jul 11, 2002 06:05 AM
