Prelude problem.. 5th to 2cd downshift ( oops? )
Posting for a friend :
I did a quick downshift from 5th to 2nd and my revs immediately jumped to around 10k I threw it back to neutral as I saw the needle fly WAY past redline and I heard a huge bang from my motor. The clutch pedal was "stuck" to the ground and I couldn't put it into gear. So I pulled over to the side of the road and manually pulled my clutch pedal back up with my hands and all of the stiffness in the pedal was gone and it wouldn't go into gear. So I had to have my car get tolled home. It was suppose to be a 5th gear to 4th gear downshift, but I did it too quickly and blame my own stupidity for this.
Here are some symptoms that I'm having with my car:
1. Won't go into gear
2. No stiffness in the clutch pedal whatsoever
3. Idle is fine at 700-750
4. When I rev it from 1k-2k, it vibrates the whole motor/frontend
5. Rev past 2k and the vibrating is still there but not as bad as 1k-2k
6. No CEL (check engine light)
Does anyone know what could possibly be wrong with the motor? (headgasket, valvetrain, rods, clutch assembly, flywheel, etc.)
My thoughts is his syncro's are blown
I would say its your clutch assembly. Pull the tranny and look at your clutch/flywheel.
I have done the 4th to 2nd acouple times with my H22a..
Nothing broke thank god.
I think you may have spun a bearing too. I think CHK4TIX had the same issue when he revved up his old motor.
Can anyone confirm this??
Also, I think your clutch is trashed. You over revved it.
I hope I am wrong though.
Good luck!!
Good luck!!
There is a reason why they call it, "The Money Shift".
I did it once. I always wondered how people could do it without knowing. Fortunately, I did it at around 60mphs. RPMs shot up to redline and I immediately pushed in the clutch. Now, when I downshift to 4th....I pull the shifter differently.
I don't know how anything could be "loose" in the tranny. If something is loose...that means it broke. I think it is the clutch that is trashed. OEM clutches are not designed to rev that high that quickly.
Let us know how it turns out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">There is a reason why they call it, "The Money Shift".
Let us know how it turns out. </TD></TR></TABLE>
i've misshifted once. shifting from 3-4 and i went into 2nd by accident. only time my h23 has seen 9k+ rpms. it happened for a split second because i also immediately pushed the clutch back in. everything seemed to be okay. *whew*
since the clutch doesn't seem to be engaging, then the clutch disc/pressure plate is screwed up. and the vibrations may be coming from that assembly now possibly being off balanced. there's probably no pedal pressure because the fork isn't engaging/disengaging the throw out bearing.
the spherical bolt that the release fork pivots on has broken in my tranny before and i had to rev-match my shifts to get the car home. i also couldn't come to a complete stop either otherwise i'd have to turn the car off, manually put the car into 1st gear, and crank it back up to get it going again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker »</TD></TR><TR><TD CLASS="quote">
same thing happened to me, i got lucky too....
i agree that your clutch is probably trashed.
</TD></TR></TABLE>same thing happened to me, i got lucky too....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SsTiNgEr77 »</TD></TR><TR><TD CLASS="quote">thinkin he blew the clutch springs and bent the valves because he floated vtec</TD></TR></TABLE>
floated vtec?
anyway
you more than likely destroyed your clutch and there is a strong likelyhood you atleast f'd some valves
dont start it anymore, dont rev it, take it to a mechanic
floated vtec?
anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SsTiNgEr77 »</TD></TR><TR><TD CLASS="quote">Posting for a friend :
I did a quick downshift from 5th to 2nd..... The clutch pedal was "stuck" to the ground ........ So I .... pulled my clutch pedal back up with my hands and all of the stiffness in the pedal was gone and it wouldn't go into gear.
Sounds to me like you bent the hell out if your shift fork, which inturn might have screwed up your clutch disk/pressure plate. Go look between the engine and the radiator at the slave cylinder, is the metal piece that is coming out of the tranny (that the slave cylinder pushes) loose?
As far as your engine vibrations go, how may miles are on the engine? Also is it just vibration or it there any tapping or knocking noise that you hear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M »</TD></TR><TR><TD CLASS="quote">
dont start it anymore, dont rev it, take it to a mechanic</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 »</TD></TR><TR><TD CLASS="quote">i went top of 3rd into 2nd. my clutch is fine
gotta love an oem clutch.</TD></TR></TABLE>
too bad you couldn't say the same about your valves
gotta love an oem clutch.</TD></TR></TABLE>too bad you couldn't say the same about your valves
i did the same thing, except i went into 3rd gear instead of 5th when i was powering downhill on the freeway.
the clutch stayed down stuck like your's did, but i was able to pop it out by slamming on it a couple times. they car seemed to drive fine so i continued on my way. then the next morning when i started her up, i sounded like the engine wanted to die.
i ended up being a loose valve. so that was fixed by a simple valve adjustment.
sounds like the clutch on yours needs to be replaced..mine was fine(that was 30,000miles ago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 »</TD></TR><TR><TD CLASS="quote">the same way you shift from 3rd to 2nd while racing. not paying attention.
Um 3rd to 2nd is easier than 5th to 2nd so dont give me that
. Why don't you try going on the freeway and shifting from 5th gear at 60mph+ to 2nd, it's near impossible to move.
</TD></TR></TABLE>Um 3rd to 2nd is easier than 5th to 2nd so dont give me that
actually it's not as hard as it seems. like i said. not paying attention can cause that. hell i've grabbed it out of 5th and accidentally went to 2nd before. when people try to "force" the car into gear very rapidly. mishifting happens frequently.
i accidently did that as well except i wa sin 4rth and i was racing a SI and when i went into 4rth i went into 2nd on accident and the clutch was stuck to the floor........ i was hella scare dbut i just lifted up the pedal and i have never had a problem with it after nothing seemd to go wrong........
I would say Clutch....I did a 3rd to 2nd and blew my clutch on my old 97 to shreds. Nothing else happoned to my car thank god, but I have seen horror stories of a RSX-r that somone on this site put up where he shot alot of block through the oil pan
take it to the mechanic so the car can be evaluated to see what damage actually occured. If you heard a bang you have valvetrain damage.
ur clutch disk is toast...your pressure plate should be fine... jsw1gga1 did that on his car not too long ago...ACT clutch was in fibers...looked like someone hair getting shaved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chidoks »</TD></TR><TR><TD CLASS="quote">ur clutch disk is toast...your pressure plate should be fine... jsw1gga1 did that on his car not too long ago...ACT clutch was in fibers...looked like someone hair getting shaved</TD></TR></TABLE>
hopefully the clutch didnt shatter too much and destroy the disk.
i let my dad drive mine right after i got it. 98mph misshift to second from third. 23,000 miles later nothing wrong thank god!
