Possibly adding nitrous and have some questions.
Old Feb 5, 2003 | 09:09 AM
lildrgn2.0's Avatar
New User
Default Possibly adding nitrous and have some questions.
Ok. I have a 96 Vtec Lude.
Current mods
I/H/E
SS Valves
3 Angle valve job
and a mild debur on the intake side.
I am considering ordering nitrous, just to play with for a bit, but I have OBDII. Now, I have heard, that I can slot the bottom bolt on the distributor so I can retard/advance the timing. I have done the OBDII work around (cutting the wire on the ECU so it does not go out and fix things that it thinks are wrong), so will slotting the bolt work?
I figure I have to retard the timing a bit to use Nitrous, and get colder plugs. I am also planning on getting a MSD 6AL (getting the AL so the spray will only activate after 5k).
Also, what shot can I safely run at this point? Eventually I want to boost too, but by then the engine will be built up the rest of the way to handle all the extra goodies.
I was thinking just about playing it safe and staying with a 75 wet shot, but I want other opinions.
Thoughts?
If I dont boost, I think I will just up the compression to 11:1 and spray a smaller shot.. but once again... opinions needed.
Old Feb 5, 2003 | 09:20 AM
lildrgn2.0's Avatar
New User
Default Re: Possibly adding nitrous and have some questions. (Lildrgn Half EVIL)
Also, since I am very unfamiliar with MSD products. Is their a difference in the 6AL for a B18 and a 6AL for a H22?
Old Feb 5, 2003 | 10:16 AM
Finest's Avatar
Hmm, never heard of anyone slotting the dist to change timing. I believe there's still the matter of the crank sensor by the timing belt that still oversees everything. So i don't know if that'll work or not. Isn't there an attachment to the MSD ignition to retard timing? I assume that's the only way to trim timing without physically switching over to OBD-I.
As for the nitrous, there are plenty of people running anywhere from 55-75 without incident. Just be careful and watch your motor closely. And listen for detonation, so you'll know when to back off.
And why would you want it only @ 5k rpms? You can start off @ 3k and run it til 7.5k easily. Just don't run it any LOWER or hit the rev limiter. (Rev limiter = fuel cut = BOOM!)
Old Feb 5, 2003 | 10:20 AM
DsITR's Avatar
Default Re: Possibly adding nitrous and have some questions. (98CTRCoupe)
You should IM the nitrous guru of the board.
Laughin XX
I don't know **** bout nitrous...otherwise I would lend more advice.
Old Feb 5, 2003 | 01:11 PM
lildrgn2.0's Avatar
New User
well if I also remember correctly the 96 OBDII.. is not really OBDII..
It has extra sensors and stuff, but thats about it.. no autocorrecting crap..
I could be wrong though..
Old Feb 5, 2003 | 01:22 PM
Boostless97Lude
Guest
Posts: n/a
it's "real" OBDII, there was some kind of law made by the EPA that all 96+ cars had to be OBDII....... but anyways, the nitrous guru is laughinxxx, and BTW, high compression is BETTER for nitrous, so, the higher compression, the more nitrous you should put to it, as long as it has forged internals of course.
Old Feb 5, 2003 | 01:23 PM
lildrgn2.0's Avatar
New User
Default Re: Possibly adding nitrous and have some questions. (Boosted97Lude)
hmmmm then 12:1... HERE I COME.. ha
Old Feb 5, 2003 | 01:45 PM
3gLudeH22A's Avatar
Someone correct me if im wrong, but the MSD (6A,6AL,Dig6) are all the same. Just that there are extra wires for 6 and 8 cyl engines.
Old Feb 5, 2003 | 01:50 PM
laughinxxx's Avatar
New User
The MSD dig 6 is good ****. I ditched my MSD 6A in favor of it for this season. Basically, you connect the pink wire from the dig 6 up to the wire that gives power to the nitrous noid. Whenever the pink wire sees 12V(In other words when you spray nitrous) it will knock your timing back for you. I've ridden around with manually retarded timing and it sucks. The low end power is horrible and launching becomes a PITA.
A 75 shot will be fine, but pick up some NGK-BKR7E plugs. Summit sells them and they are cheap.
Stay away from any NOS kit with super powershot solenoids. I spent all of last season blowing them out. The cheater or proshot noids work much better. Roby on here sells them for a good price. The route is NX, which makes good wet kits.
Besides the retarded timing and colder plugs you'll need a purge kit to purge the shitty nitrous out of the line before your runs, and to relieve pressure in the line after you finish your run and close the bottle. http://www.speedshop.org has nice purge kits and bad *** pressure regulated bottle heaters. You are in AL so I doubt you'll need one, but nitrous needs to be at about 85 degrees for optimum power. If you don't have temps around that get the heater.
The bare minimum to get is the plugs, retarded timing(Dig 6), purge kit, and a bottle mounted nitrous pressure gauge.
Old Feb 5, 2003 | 02:32 PM
lildrgn2.0's Avatar
New User
Default Re: Possibly adding nitrous and have some questions. (laughinxxx)
you are the man..
so the dig 6 will retard my timing for me.. even though I am OBDII?
Old Feb 5, 2003 | 08:22 PM
laughinxxx's Avatar
New User
you are the man..
I am almost positive that it will. If you want to make absolutely certain call up MSD's tech line: (915) 855-7123
vmsturbo
Aug 21, 2004 06:29 PM
8891hatchs
Jun 14, 2004 07:27 PM
NirVTEC
Mar 1, 2003 09:25 PM
ExodusX187
Feb 24, 2003 06:00 AM
twizt2
Dec 19, 2001 12:03 PM
