piston on n/a
Old Mar 28, 2004 | 02:25 PM
jackedcrew's Avatar
Default piston on n/a
hey i was just wondering what compression pistons i should get? my car is a daily driver and i dont want a lot of problems with it. also i was looking into type s pistons but i want a higher compression than 11:1. what is the highest comp pistons i can get without harming anything.
Old Mar 28, 2004 | 02:59 PM
Kal's Avatar
Kal
Default Re: piston on n/a (jackedcrew)
12-12.5:1 would be the highest i would go on pump gas. you'll need to go to the local dyno and tune your car after installing it. you won't get any problems if you tune it correctly. type-s pistons are good for their price but i prefer something that bumps compression higher than just by 1
Old Mar 28, 2004 | 03:14 PM
jackedcrew's Avatar
Default Re: piston on n/a (Kal)
yeah my friend has 12.25:1 pistons in a bone stock gsr but i've been hearing that in an h22a4 it isn't safe to go above 11:5. i've also heard you have to sleeve your block to run above 12:1 pistons in an h22 but i think thats bs. i would like to run 12:1 pistons. what else would i need to run them safely on 93 octane.(daily driver)
I have every bolt on and a vafc and im ready for some internals.
Old Mar 28, 2004 | 03:43 PM
h22apwrd95's Avatar
I'm not going to say that running forged pistons on the stock block isn't a risk, because it is. But I will leave that up to you. I did it with some wiseco 8.8:1's and the car ran well. But it also did a little damage. I think that a properly clearanced stock block would be the way to go. And I love my JE's on a relatively cheap sleeving job.
Mike
Old Mar 28, 2004 | 03:45 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackedcrew &raquo;</TD></TR><TR><TD CLASS="quote">yeah my friend has 12.25:1 pistons in a bone stock gsr but i've been hearing that in an h22a4 it isn't safe to go above 11:5. i've also heard you have to sleeve your block to run above 12:1 pistons in an h22 but i think thats bs. i would like to run 12:1 pistons. what else would i need to run them safely on 93 octane.(daily driver)
I have every bolt on and a vafc and im ready for some internals.</TD></TR></TABLE>
gsr sleeves are steel, H22a sleeves are FRM that's why you have to sleeve.
Old Mar 28, 2004 | 04:28 PM
Speedra500's Avatar
I good option would be to get type S pistons with a thin headgasket to get about 11.5:1, and also some good aftermarket rods that support a full floating wrist pin, however you can slightly bore out your stock rods to fit a full floating wrist pin like the type s piston, and you could do some cryo treating or shot peening, but some new lightweight I-beam rods probably wouldnt run you too much money, gl
Old Mar 28, 2004 | 04:30 PM
h22mark's Avatar
Default Re: piston on n/a (satan_srv)
Well, I would like to know what type of sleeves would be good for the compression on a NA setup, i.e darton, golden eagle etc.
Old Mar 28, 2004 | 04:32 PM
Kal's Avatar
Kal
Default Re: piston on n/a (h22mark)
it's just a matter of choice... they function all in the same regards
Old Mar 28, 2004 | 04:57 PM
accord387's Avatar
If your goign to run N/A, you could just go with a local machine shop sleeves you dont need darton or golden eagle
Old Mar 28, 2004 | 07:44 PM
jackedcrew's Avatar
Default Re: (accord387)
alright so 11.5:1 is prob the safest which is what i thought i just wanted to make sure. i know high comp pistons make a difference cuz my friends gsr dropped a sec off his 1/4 mile time just with 12.25:1 pistons and intake. no joke! thats why i wanted to get as high comp as possible without having problems. and i've heard bad things about all motor h22's but screw it im goin all motor vtec hits hard as **** and it's loud as hell just with my bolt-ons. thanks.
Ryan#1
Oct 2, 2008 06:27 PM
Shorty C
Apr 1, 2004 11:24 PM
respectblades
Jun 23, 2003 09:08 PM
TurboT
Nov 28, 2001 01:42 PM
