P13 Knock Sensor Question?????
Old Feb 2, 2005 | 11:45 AM
4DRPIMPIN's Avatar
Default P13 Knock Sensor Question?????
I have a p13 ecu for a h22. The motor has a knock sensor but is not hooked up. The ecu is not throwing a code for it. My question is does the jdm p13 ecu look for a knock sensor? what about the usdm ecu? Does it affect the performance of the motor being not hooked up? thanks in advance.
Old Feb 2, 2005 | 11:48 AM
Under_Pressure's Avatar
Default Re: P13 Knock Sensor Question????? (4DRPIMPIN)
Both jdm and usdm look for a knock sensor. Yes it does affect your car it goes into safe mode. Why your ecu is not throwing I have no clue. Is the ecu a virgin??? You might have a chipped ecu, See if you can go over 120 if its a jdm. If you can and its jdm it’s chipped.
jad67
Mar 8, 2015 12:41 PM
balbowskie
Engine Management and Tuning
22
Feb 16, 2013 11:38 AM
MONSTERek4
Jul 9, 2009 07:25 PM
ninkei
Nov 15, 2005 04:45 PM
gsrteg
Aug 15, 2002 02:39 PM
