p13 on h23?
Old Jul 2, 2004 | 03:04 AM
hOndafienD 04's Avatar
Default p13 on h23?
can i run this??? i have a p13 layign around and wanted to try it...i know i'll prob get a CEL cuz it won't have the vtec wiring.....but i'd still like to try it, and try to take the revs a little higher...like 7 g's instaed of 6500...
Old Jul 2, 2004 | 03:05 AM
gaydm.accord's Avatar
edit: i was being an *** im sorry hahahhaha
Modified by gaydm.accord at 4:44 AM 7/2/2004
Old Jul 2, 2004 | 03:12 AM
95PreludeSi's Avatar
Default Re: p13 on h23? (hOndafienD 04)
I don't know if it will work, but installing the p13 to move the rev limiter higher is a bad idea. H23 is a good motor, but I think most will agree it shouldn't be reved any higher than the stock red line. The bearings will not like it.
Old Jul 2, 2004 | 03:17 AM
Default Re: (gaydm.accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">flame suit on </TD></TR></TABLE>
**** you ^^^^^^^
95prelude si...
thanx for the reply, yeah thats what i was thinking but wanted to know if i could benifit in power with just the p13 ecu....keeping my shifts under 6500??
Old Jul 2, 2004 | 03:30 AM
or maybe a p74/75 for the ls's??? im looking for something that i can chip in the future...or use hondata on...
Old Jul 2, 2004 | 03:33 AM
lighten up grasshopper you wont get very far with that attitude
you wouldnt use a vtec ecu on a non vtec motor
edit: unless it was h23 with h22 head
Old Jul 2, 2004 | 03:53 AM
Default Re: p13 on h23? (95PreludeSi)
Well, I can't really comment on what it would do for you under 6500rpm. It seems like most people that have upgraded who originally ran p13's either went with a hondata or maybe a chipped gsr ecu. I don't know much more than this though, I'll leave it to someone else who knows to reply. Goodluck.
Old Jul 2, 2004 | 05:42 AM
AndyD's Avatar
It's not going to work. It has different air/fuel mappings. It won't run right. Besides, why do you want to rev up to 7000rpms? You will only be putting unnecessary stress on the motor while not making anymore power.
Rule of thumb: Just because you rev higher doesn't mean you are going faster or making more power. That's why dynos are so important.
Old Jul 2, 2004 | 03:07 PM
satan_srv's Avatar
Default Re: p13 on h23? (AndyD)
that's a dumb idea. The non-VTEC tune of the p13 is for less performance than a P14 h23 ecu would. then everytime you would hit 4900rpms you would go into limp mode and your car would run like ****.
Old Jul 2, 2004 | 05:50 PM
SKDRCR's Avatar
Default Re: p13 on h23? (satan_srv)
Even if the ecu was compatable, it would be pointless
because most h23's peak before 6000 anyways.
Old Jul 2, 2004 | 06:18 PM
satan_srv's Avatar
Default Re: p13 on h23? (SKDRCR)
plus the p13 drives 345cc injectors...the h23 has 240cc injectors it would run hella lean and probably destroy your motor
Old Jul 2, 2004 | 07:17 PM
T-Mo's Avatar
Just put on a vtec tranny. I did this tranny swap when a mechanic replaced my axles, and didn't put new seals. My tranny fluid leaked out and I blew my tranny. Anyways they had to buy me a new tranny. So I got a Vtec one. I noticed a big difference in shifting
94lude_si
Oct 14, 2006 11:56 AM
95hondaprelude
Nov 3, 2004 07:37 PM
B18CUL8R
May 28, 2004 07:43 AM
BoostedH23a1
Nov 25, 2003 09:25 PM
shyboy_02
Sep 28, 2003 09:12 PM
