overheating problem
Old Feb 5, 2007 | 08:24 AM
turbols99's Avatar
Default overheating problem
I have a 1990 honda prelude and I think the head gasket is blown. It blew out white smoke through the tail pipe. The water pump seems to be pumping. I wonder if the thermostat could be bad and not opening to cause the car to over heat and cause the head gasket to blow. If anybody have any info, it would be greatly appreciated.
Old Feb 5, 2007 | 10:51 AM
Speedra500's Avatar
Default Re: overheating problem (turbols99)
it would have to overheat for a little while before the headgasket would get messed up. If you're car starts getting too hot, turn it off so you dont warp the head. If it started smoking it sounds very likely that the headgasket is blown
Old Feb 5, 2007 | 03:03 PM
1GPlusSH's Avatar
white smoke...burning water. either water in the gas or water getting past the head
Old Feb 5, 2007 | 07:28 PM
lude98SH's Avatar
Default Re: overheating problem (1GPlusSH)
First of all see if u are actually loosing coolant. If you are first check ur radiator, coolant lines and seal around the water pump.
If you find that you are loosing coolant and none of those things are happening. Then you may have a head gasket problem or even worse a cracked head or block. Those are the worst case things though.
Are you overheating ?
D3vin
14
Mar 14, 2010 08:41 PM
jermie_jrmz
Honda Civic (2001 - 2005)
12
Dec 27, 2009 01:26 AM
Gumbey75
Feb 23, 2005 04:08 PM
whagkangmakulet
Sep 23, 2002 06:43 AM
veejay
Jun 30, 2001 09:02 AM
