Overheating
Old Jan 3, 2007 | 05:23 PM
importfanatic17's Avatar
Default Overheating
There was a hole in one of my hoses and it caused the car do gulp coolant and overheat. Well, I replaced the hose and poured an entire jug of Honda's coolant in the radiator and it still gets really hot when just sitting. WTF?
P.S.
It is normal temp. when driving at moderate speeds.
Old Jan 3, 2007 | 05:24 PM
TopEndUSA's Avatar
Default Re: Overheating (importfanatic17)
subscribed
Old Jan 3, 2007 | 05:37 PM
Default Re: Overheating (MardreRacing)
Could it be a bad thermostat? If so, what temp does the thermo. turn the fans on?
Old Jan 3, 2007 | 05:49 PM
SuperSlow's Avatar
did you flush bubbles out properly after refill?
Old Jan 3, 2007 | 06:18 PM
ludeing1's Avatar
you need to bleed your system. do this ; warm your car find the bleeder value right past the dist. (looks like the bleeder thats on your breaks you will see a hose going into it) after its good and warm open with a 10 mm socket and ext. (i think its 10mm ) n e way do that bout 2 or 3 times and you should have removed any air thats trapped,,,,,,,,jt
Old Jan 3, 2007 | 06:21 PM
ludeing1's Avatar
one more thing just take your thermo out unless you live in the snow
Old Jan 3, 2007 | 11:02 PM
SuperSlow's Avatar
Default Re: (ludeing1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeing1 &raquo;</TD></TR><TR><TD CLASS="quote">one more thing just take your thermo out unless you live in the snow</TD></TR></TABLE>permanently removing your t-stat will cause your engine to take a longer time to reach normal operating temperature, thus decreasing its efficiency and gas mileage. Removing the thermostat is about as intelligent as removing your o2 sensors...
However, if you live in the philippines, then nevermind, as ambient temperatures in the sun throughout the year are quite high...
Old Jan 4, 2007 | 05:05 AM
ludeing1's Avatar
well i live in a climate thats not to harsh and i have no problem with my car warming up, but then again i've had less problems with overheating so it doesnt really matter unless you live in a really cold enviroment. as for gas mileage and efficiency?? are you kidding me? staying out of vtec will save you more then doing this + for someone thats looking for gas mileage and effciency forget about modifying your engine for power even if its said a cold air intake will give you better gas economy thats rubbish, your computer has to conpensate for the airflow adding more fuel, if it didnt you would run leaner, so in return if gas efficiency is your biggest concern go buy a insight or go hybrid. if you werent intrested in speed and or custom then you ultimetly wouldnt be at this site reading about boost, swapping engines, adding cams, racing, ect...
Old Jan 4, 2007 | 05:29 AM
kulrevon's Avatar
yeah but when you car is cold ie warming up it is running in cold start mode. if you take out your thermostat it takes longer to heat up and longer to get out of cold start mode.
when you are in cold start mode your car uses a a lot more fuel but doesn't necessarily give you more power.
Old Jan 4, 2007 | 10:28 AM
SuperSlow's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">yeah but when you car is cold ie warming up it is running in cold start mode. if you take out your thermostat it takes longer to heat up and longer to get out of cold start mode.
when you are in cold start mode your car uses a a lot more fuel but doesn't necessarily give you more power. </TD></TR></TABLE>Exactly.....
Old Jan 4, 2007 | 11:43 AM
Default Re: (SuperSlow)
I fixed the problem but I think I'll leave in my thermostat. What temp. does it kick on?
Old Jan 4, 2007 | 02:57 PM
kulrevon's Avatar
Default Re: (importfanatic17)
170 or 180 depending on which you buy if its not oem. it can be others but these a readily availible at autopartsstores.
what did your problem end up being?
Old Jan 4, 2007 | 04:04 PM
ludeing1's Avatar
cold start mode huh.. what exactly happens in cold start mode?
Old Jan 4, 2007 | 07:25 PM
I think there was some air in the system. I reflushed the system and made sure ALL the air bubbles were gone and it has been good since
Old Jan 4, 2007 | 09:14 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfanatic17 &raquo;</TD></TR><TR><TD CLASS="quote">I think there was some air in the system. I reflushed the system and made sure ALL the air bubbles were gone and it has been good since</TD></TR></TABLE>
Yep, always bleed anytime you do anything that involves the cooling system.
aziaticvang
Jan 17, 2008 06:32 PM
snowblind7x
Feb 21, 2007 08:58 PM
175Shot4Door
Sep 18, 2006 07:51 AM
john457
15
Dec 21, 2005 05:36 PM
BoostNEF
May 14, 2005 01:18 AM
