over revving question.
Old Apr 4, 2012 | 09:05 PM
horsepowerless's Avatar
Default over revving question.
Ok, so I have an OBDI jdm h22a swapped into my 96 prelude that was originally OBDII(the 92-95 4th gens were OBDI, and i have the odd ball... lucky me.)
Anyway, the stock redline, at least on usdm models, is 7200, and the fuel cut is 7500. i was screwing around yesterday and noticed that in first gear i can rev to at least 7800, and there is no fuel cut...
What I want to know is whether or not this is bad for my engine to rev this high on stock internals. I'm hoping not, because it keeps me a lot closer to my peak horsepower if i rev that high before shifting. This in turn will bring down my 1/4 mile time.
Old Apr 4, 2012 | 10:52 PM
Enzo15's Avatar
Default Re: over revving question.
A stock H22a actually peaks earlier than that. It actually peaks around 6500. Every engine is slightly different, but your would be close as well. Now if you have changed anything like cams, or header then you might shift your peak point.
Old Apr 5, 2012 | 02:46 AM
minilogoguy18's Avatar
Don't believe what the tachometer is telling you, it becomes more inaccurate the higher it counts.
Old Apr 5, 2012 | 05:58 AM
Tight-R's Avatar
I thought the USDM limiter was 8200? Given, that motor DOES NOT make power there, and there is absolutely no reason to shift that high. Notice thread, after thread, after thread, of spun bearing H22's. Think about why that could be? Just think.
Old Apr 5, 2012 | 10:42 AM
Thats kind of what I was thinking... wikipedia says different ones can rev as high as 8 though... but i know wiki is also a hit-and-miss on its accuracy sometimes.
I also found this:
H22A
200 PS (147 kW; 197 hp) @ 6,800 rpm & 161 lb·ft (218 N·m) @ 5,500 rpm
So If I shift at 8k or just before i drop down to about 6k rpm.. which means I'm going from 1k under my peak power to 1k over.. which to me seems better than shifting at 7500 which is putting me around 1.5k under my peak to just .5k over.. so basically staying farther from my peak.
mondiex
Jun 20, 2012 05:42 PM
landroveraz
Engine Management and Tuning
Sep 13, 2009 05:37 PM
EGmikeH22
10
Jul 4, 2004 10:48 AM
bEE338
Jun 24, 2003 06:34 PM
RudeLude
Mar 4, 2003 11:45 PM
